My notes on compiling LiteX-CNC on linuxCNC
12 Oct 2022 19:03 #254029 by DePrutser
Replied by DePrutser on topic My notes on compiling LiteX-CNC on linuxCNC
The commands above do generate the verilog code, but not the bitstream. In the directory 5a-75e there's the script build_colorlight_5a_75e.sh:
$ cat build_colorlight_5a_75e.sh
# Autogenerated by LiteX / git: ac369977
set -e
yosys -l colorlight_5a_75e.rpt colorlight_5a_75e.ys
nextpnr-ecp5 --json colorlight_5a_75e.json --lpf colorlight_5a_75e.lpf --textcfg colorlight_5a_75e.config --25k --package CABGA256 --speed 6 --timing-allow-fail --seed 1
ecppack --bootaddr 0 --compress colorlight_5a_75e.config --svf colorlight_5a_75e.svf --bit colorlight_5a_75e.bit
as the paths on my machine are not setup correctly, I had to adjust this script to include the full locations:
$ cat my_build_colorlight_5a_75e.sh
set -e
/home/cedric/oss-cad-suite/bin/yosys -l colorlight_5a_75e.rpt colorlight_5a_75e.ys
~/oss-cad-suite/bin/nextpnr-ecp5 --json colorlight_5a_75e.json --lpf colorlight_5a_75e.lpf --textcfg colorlight_5a_75e.config --25k --package CABGA256 --speed 6 --timing-allow-fail --seed 1
~/oss-cad-suite/bin/ecppack --bootaddr 0 --compress colorlight_5a_75e.config --svf colorlight_5a_75e.svf --bit colorlight_5a_75e.bit
Now the script runs correctly:
$ sh my_build_colorlight_5a_75e.sh
| yosys -- Yosys Open SYnthesis Suite |
| Copyright (C) 2012 - 2020 Claire Xenia Wolf <This email address is being protected from spambots. You need JavaScript enabled to view it.> |
| Permission to use, copy, modify, and/or distribute this software for any |
| purpose with or without fee is hereby granted, provided that the above |
| copyright notice and this permission notice appear in all copies. |
| THE SOFTWARE IS PROVIDED "AS IS" AND THE AUTHOR DISCLAIMS ALL WARRANTIES |
| WITH REGARD TO THIS SOFTWARE INCLUDING ALL IMPLIED WARRANTIES OF |
| MERCHANTABILITY AND FITNESS. IN NO EVENT SHALL THE AUTHOR BE LIABLE FOR |
| ANY SPECIAL, DIRECT, INDIRECT, OR CONSEQUENTIAL DAMAGES OR ANY DAMAGES |
| WHATSOEVER RESULTING FROM LOSS OF USE, DATA OR PROFITS, WHETHER IN AN |
| ACTION OF CONTRACT, NEGLIGENCE OR OTHER TORTIOUS ACTION, ARISING OUT OF |
| OR IN CONNECTION WITH THE USE OR PERFORMANCE OF THIS SOFTWARE. |
Yosys 0.21+10 (git sha1 a21745052, clang 10.0.0-4ubuntu1 -fPIC -Os)
-- Executing script file `colorlight_5a_75e.ys' --
1. Executing Verilog-2005 frontend: /home/cedric/LiteX-CNC/5a-75e/gateware/colorlight_5a_75e.v
Parsing Verilog input from `/home/cedric/LiteX-CNC/5a-75e/gateware/colorlight_5a_75e.v' to AST representation.
Storing AST representation for module `$abstract\colorlight_5a_75e'.
Successfully finished Verilog frontend.
2. Executing ATTRMAP pass (move or copy attributes).
3. Executing SYNTH_ECP5 pass.
<snip>
Warning: Max frequency for clock '$glbnet$crg_clkout0': 42.39 MHz (FAIL at 50.00 MHz)
Warning: Max frequency for clock '$glbnet$eth_clocks_rx$TRELLIS_IO_IN': 112.17 MHz (FAIL at 125.00 MHz)
Info: Max delay <async> -> posedge $glbnet$crg_clkout0 : 2.90 ns
Info: Max delay posedge $glbnet$crg_clkout0 -> <async> : 5.18 ns
Info: Max delay posedge $glbnet$crg_clkout0 -> posedge $glbnet$eth_clocks_rx$TRELLIS_IO_IN: 2.22 ns
Info: Max delay posedge $glbnet$eth_clocks_rx$TRELLIS_IO_IN -> posedge $glbnet$crg_clkout0 : 1.84 ns
Info: Slack histogram:
Info: legend: * represents 47 endpoint(s)
Info: + represents [1,47) endpoint(s)
Info: [ -3591, 649) |****+
Info: [ 649, 4889) |*****************+
Info: [ 4889, 9129) |****************************************************+
Info: [ 9129, 13369) |************************************+
Info: [ 13369, 17609) |************************************************************
Info: [ 17609, 21849) |******************************************+
Info: [ 21849, 26089) |
Info: [ 26089, 30329) |
Info: [ 30329, 34569) |
Info: [ 34569, 38809) |
Info: [ 38809, 43049) |
Info: [ 43049, 47289) |
Info: [ 47289, 51529) |
Info: [ 51529, 55769) |
Info: [ 55769, 60009) |
Info: [ 60009, 64249) |
Info: [ 64249, 68489) |
Info: [ 68489, 72729) |
Info: [ 72729, 76969) |
Info: [ 76969, 81209) |+
2 warnings, 0 errors
Info: Program finished normally.
now the gateware directory has a lot more files:
$ ls -l
total 17716
-rw-r--r-- 1 cedric cedric 389 Oct 8 17:22 build_colorlight_5a_75e.sh
-rw-r--r-- 1 cedric cedric 214083 Oct 12 20:47 colorlight_5a_75e.bit
-rw-r--r-- 1 cedric cedric 3211208 Oct 12 20:47 colorlight_5a_75e.config
-rw-r--r-- 1 cedric cedric 10343649 Oct 12 20:46 colorlight_5a_75e.json
-rw-r--r-- 1 cedric cedric 3459 Oct 8 17:22 colorlight_5a_75e.lpf
-rw-r--r-- 1 cedric cedric 105 Oct 12 20:23 colorlight_5a_75e_mem.init
-rw-r--r-- 1 cedric cedric 2698676 Oct 12 20:46 colorlight_5a_75e.rpt
-rw-r--r-- 1 cedric cedric 453587 Oct 12 20:47 colorlight_5a_75e.svf
-rw-r--r-- 1 cedric cedric 1188497 Oct 12 20:23 colorlight_5a_75e.v
-rw-r--r-- 1 cedric cedric 303 Oct 8 17:22 colorlight_5a_75e.ys
-rw-r--r-- 1 cedric cedric 461 Oct 12 20:46 my_build_colorlight_5a_75e.sh
The file "colorlight_5a_75e.svf" can now be flashed into the FPGA board
Moderators: PCW, jmelson
Time to create page: 0.174 seconds
