Mesa - about fallback - CLOSED
  • macsddau@linuxcnc
  • macsddau@linuxcnc's Avatar Topic Author
  • Premium Member
  • Premium Member
28 Sep 2022 14:58 #252944 by macsddau@linuxcnc
Mesa - about fallback was created by macsddau@linuxcnc
Hi
Got a new 6i25.
I have some questions about fallback
  1. Is there a fallback written to EPROM when unpacking board ?
  2. If yes, witch one is it ?
  3. Again, if yes, is it required to write a new fallback ?
  4. Which one to write : a standard fallback or the same as written in user configuration block ?
28 Sep 2022 15:04 - 28 Sep 2022 15:05 #252946 by PCW
Replied by PCW on topic Mesa - about fallback
1. Yes, a fallback is written in all shipped 6I25s
2. its a configuration with no features except GPIO (in addition it blinks the /INIT LED)
3. No, normally you should never need to re-write the fallback
Last edit: 28 Sep 2022 15:05 by PCW.
The following user(s) said Thank You: macsddau@linuxcnc
  • Todd Zuercher
  • Todd Zuercher's Avatar
  • Platinum Member
  • Platinum Member
28 Sep 2022 15:09 #252948 by Todd Zuercher
Replied by Todd Zuercher on topic Mesa - about fallback
1. Yes
2. ?
3. No
4. You shouldn't need to do anything with the fall back or even need to use it, unless you screw up the firmware by installing one that is incompatible with your card that prevents it from running. Then the fall back is to help restore the card to a state that will allow you to install a functional firmware after such an incident. (It is simply a safety net to help prevent you from bricking it from doing something stupid.) It is possible to overwrite the fallback if proper procedures are not followed.
  • macsddau@linuxcnc
  • Premium Member
  • Premium Member
28 Sep 2022 15:23 #252950 by macsddau@linuxcnc
Replied by macsddau@linuxcnc on topic Mesa - about fallback - CLOSED
Thanks for your answers.
Less is better !
I will do any things with the fallback.
  • Moderator
  • Moderator
28 Sep 2022 17:50 #252960 by tommylight
Replied by tommylight on topic Mesa - about fallback - CLOSED
Not ??? :)
  • macsddau@linuxcnc
  • Premium Member
  • Premium Member
28 Sep 2022 19:07 #252965 by macsddau@linuxcnc
As I anderstand, Mesa cards have fallback writen. So I don't need to make some thing.
Is there any thing to know ?
  • Moderator
  • Moderator
28 Sep 2022 23:18 #252971 by tommylight
Reminder, you forgot to add "not" there.
While on the subject, today i found out why some think they should do a fallback, in the manual, section "operation" subsection "mesaflash" there is a list of commands for use with it, it would be advisable to move the fallback commands to the "service" or "in case of a bad flash due to power cut or wrong bitfile" section of the manual.
This is the second time i read of users asking about fallback, and one already tried to do that flash verbatim from the manual.
  • macsddau@linuxcnc
  • Premium Member
  • Premium Member
29 Sep 2022 08:12 #252998 by macsddau@linuxcnc
Sorry Tommylight, I haven't a very good english understanding . Can you explain in other world what you explain.
  • Moderator
  • Moderator
29 Sep 2022 09:22 #253006 by tommylight
You forgot to add "not" there, it was just a reminder, it should be
I will NOT do any things with the fallback.
Nevermind, we know what you were saying, do not worry. :)
Moderators: PCW, jmelson
Time to create page: 0.123 seconds
