Servo Axis Jumps Around Randomly
- 42walrustitan
08 Oct 2022 23:26 #253783
by 42walrustitan
Servo Axis Jumps Around Randomly was created by 42walrustitan
Recently my cnc router, which has never really had any issues, started having a problem with its Y-axis. The servo motor when moving will randomly move around at its highest speed. I do not know what has caused this and any help would be appreciated.
- Thank you received: 7491
09 Oct 2022 00:19 #253784
Replied by tommylight on topic Servo Axis Jumps Around Randomly
Assuming it is a DC motor, do check the encoder and encoder wires on both sides of the cable, or change the encoder.
If all that checks OK, change the drive.
- jmelson
- Thank you received: 126
09 Oct 2022 01:58 #253796
by jmelson
Replied by jmelson on topic Servo Axis Jumps Around Randomly
Try shaking the cables to a motor that moves, like on a gantry. The cable may be going bad or there could be a broken wire at one end. Tell us what motor and drive are being used.
Jon
Jon
- 42walrustitan
09 Oct 2022 18:33 #253817
by 42walrustitan
Replied by 42walrustitan on topic Servo Axis Jumps Around Randomly
Through some testing I have determined that the servo itself has gone bad. I can't seem to find a place to get a new one though. It is a Dae Hwa D625-30B7-TC10. Is there a place I should start looking.
22 Oct 2022 11:04 #254747
Replied by andypugh on topic Servo Axis Jumps Around Randomly
Set up a saved search on eBay maybe?Through some testing I have determined that the servo itself has gone bad. I can't seem to find a place to get a new one though. It is a Dae Hwa D625-30B7-TC10. Is there a place I should start looking.
