Mesa 7i96S+7i74+ 3pcs 7IA0 ???
- zz912
- Thank you received: 98
15 Oct 2022 17:54 #254181
by zz912
Mesa 7i96S+7i74+ 3pcs 7IA0 ??? was created by zz912
Hello,
My friend bought a 7i96S card and already has it at home. He found that he would need at least 100 inputs and at least 50 outputs. I know that RS485 IO can be used, but we want to build a machine on Mesa cards.
I figured we would use:
7i96S + firmware 7i96s_7i74d.bin
7i74 connect to P1
3pcs 7IA0 connect to 7i74
I have never used SmartSerial before. I wanted to ask if this combination would work. Can the 7i96S handle that much IO? These cards aren't cheap, so I'd hate to recommend something that doesn't work.
7i74 connect to P1
- Thank you received: 5334
15 Oct 2022 19:22 - 15 Oct 2022 19:27 #254189
Replied by PCW on topic Mesa 7i96S+7i74+ 3pcs 7IA0 ???
That combination will work (any sserial card combination should work)
but is more expensive than using 7I84 or 7I84D cards.
(if you don't need 2A isolated outputs or selectable sinking/sourcing inputs)
Last edit: 15 Oct 2022 19:27 by PCW.
The following user(s) said Thank You: zz912
- zz912
16 Oct 2022 05:13 #254203
by zz912
Replied by zz912 on topic Mesa 7i96S+7i74+ 3pcs 7IA0 ???
7i84 will better for us.
Exist some cable between 7i96S P1 and 7i74?
16 Oct 2022 14:21 #254227
Yes, its a simple flat cable with a IDC DB25M on one end and a IDC HDR26F
on the other (pin1 --> 1 pin1, HDR pin 26 unconnected)
Mesa lists it as:
DB25M-IDC26 CABLE
Mesa lists it as:
DB25M-IDC26 CABLE
- zz912
16 Oct 2022 17:22 #254243
by zz912
Thank you for help.
