7i97 encoder maximum voltage
- Vorms
20 Oct 2022 15:41 #254610
by Vorms
7i97 encoder maximum voltage was created by Vorms
Hello,
I would like to know what is the maximum voltage admissible for encoder.
I TTL means 0 -> + 5 V ?
Many thanks for your help.
Regards
Regards
- Thank you received: 7491
20 Oct 2022 15:59 #254614
Replied by tommylight on topic 7i97 encoder maximum voltage
Not sure, but 5.25V is still ok.
Anything over it will probably destroy something.
TTL menas 5V +-5%
so 4.75 to 5.25.
TTL menas 5V +-5%
so 4.75 to 5.25.
- Thank you received: 5334
20 Oct 2022 16:10 #254615
Replied by PCW on topic 7i97 encoder maximum voltage
Yes, the 7I97 encoder inputs expect 5V signals in TTL mode, but are
safe for a wider input range. The 7I97 encoder inputs in single ended mode
will take up to +12V, -7V signals and still operate properly.
Time to create page: 0.138 seconds
