TASM Assembler for Mesa firmware
- jrbloom
26 Oct 2022 14:53 #255102
by jrbloom
TASM Assembler for Mesa firmware was created by jrbloom
I just noticed that the Mesa hostmot2 firmware zip doesn't include the TASM assembler needed to build the D16 firmware. Does anyone know if this is available anywhere? Seems strange to supply the assembly source without a way to assemble it.
- Thank you received: 5334
26 Oct 2022 19:10 - 26 Oct 2022 19:11 #255123
Replied by PCW on topic TASM Assembler for Mesa firmware
No sure of the legal status of the Telemark assembler so I have not provided it.
(it is available from some sources like ticalc.org)
Last edit: 26 Oct 2022 19:11 by PCW.
- jrbloom
27 Oct 2022 08:21 #255170
by jrbloom
Replied by jrbloom on topic TASM Assembler for Mesa firmware
Hmmn. I tried that first and concluded it was not the correct assembler - It complains about .MACRO being an unrecognized directive and that there are misaligned labels.
Is v3.2 the correct version?
On an slight side-note, etherhm2.asm includes etherhm2.equ which isn't included in the firmware archive. There is an etherhm2.inc, so I've edited the include to point to that instead. Hopefully that's correct. But it won't assemble anyway due to the above issue.
Thanks,
Jon
Thanks,
Jon
27 Oct 2022 17:42 #255208
Not sure what version of TASM is used.
etherhm2.equ is generated from the .inc file
Since Telemark TASM seems to have been present without complaint
at ticalc.org for a long time I will post our version here along with the
other build tools.
other build tools.
- jrbloom
27 Oct 2022 17:49 - 27 Oct 2022 17:50 #255211
by jrbloom
Thank you Peter. I'll give this a try tomorrow.
MAKEINC.EXE does the .INC to .EQU conversion?
Last edit: 27 Oct 2022 17:50 by jrbloom.
27 Oct 2022 19:34 #255230
Take a look at the MAKEE.BAT file
MAKEINC converts the EQU file to an assembly include file
(it can also make Pascal or C includes)
MACRO is a general purpose macro processor
- jrbloom
28 Oct 2022 11:04 #255295
by jrbloom
Thanks Peter, I now have the tools working nicely.
For anyone else bumping into this thread in the future ... I had to run the tools through 'dosbox' on Linux (Note that they will not run on Windows).
On Fedora:
$ sudo dnf install dosbox
$ cd <path-to-hostmot>/configs/hostmot2/source/etherhm2
$ dosbox -c "mount c ${PWD}" -c "c:" -exit MAKEE.BAT
The MAKEE.BAT script will do all the work and spiut out a new etherhm2.vhd file.
On Fedora:
Time to create page: 0.107 seconds
