Mesa 7i92_7i77_7i76.bit
  • Diederik
  • Diederik's Avatar Topic Author
  • Premium Member
  • Premium Member
26 Oct 2022 19:43 #255124 by Diederik
Mesa 7i92_7i77_7i76.bit was created by Diederik
Hi there,
I'm using a 7i92,7i77,7i76 and 7i70.
I'm busy with a 5axis machine.
Firmware on the 7i92 is: 7i92_7i77_7i76D.bit
There are only 3 encoders available on this firmware for the 7i77.
I need to use all 7 encoder channels for feedback.
I also need to use all 5 stepgen channels on the 7i76.
Please could someone assist me with the correct firmware for this?
Thanks and Regards, Diekie.
26 Oct 2022 19:56 - 26 Oct 2022 23:39 #255126 by PCW
Replied by PCW on topic Mesa 7i92_7i77_7i76.bit
That firmware has 7 encoders and 5 stepgens
Note that each "Muxed QCount" FPGA pin connects to two physical encoder pins
so 3 muxed encoder pin sets interface to 6 encoders total.
This is how the 7I77 can have 6 encoder inputs (which would normally  take 18 pins or A,B,Z  times 6)
and only use 10 of the 17 available FPGA  interface pins.
Last edit: 26 Oct 2022 23:39 by PCW.
Moderators: PCW, jmelson
Time to create page: 0.078 seconds
