Mesa Configuration Tool Version 1.0.0
- JT
- Thank you received: 595
01 Nov 2022 19:26 #255685
by JT
Replied by JT on topic Mesa Configuration Tool Version 1.0.0
Interesting bug because I had not tested with a PCI board and I forgot to make the hm2 a list of lists.
JT
JT
- HansU
- Thank you received: 217
01 Nov 2022 19:39 #255687
by HansU
Good, then we know that only one of the two has a bug
Replied by HansU on topic Mesa Configuration Tool Version 1.0.0
No, it's not weird. The tool uses two different programs to create or update the ini file. If there is no ini file by the name then buildini.py is used. If the ini exists then updateini.py is used to update the ini without writing over items the use has added.
JT
- JT
01 Nov 2022 19:41 #255688
by JT
Neither one has a bug now
JT
JT
The following user(s) said Thank You: HansU, flyingbrick
- HansU
01 Nov 2022 21:10 #255695
by HansU
Great works like a charm now
Really nice that comments, other key-values and even empty lines are kept!
- JT
01 Nov 2022 21:38 #255697
by JT
Took 4 attempts and a huge amount of coding to get to the point where an ini file is truly safe. I feel so much better now that I have achieved the goal of a safe ini file.
I do appreciate your feedback and testing.
JT
JT
The following user(s) said Thank You: tommylight, Clive S, HansU, itsme, flyingbrick
Time to create page: 0.423 seconds
