low jitter
20 Nov 2022 03:35 #257140 by vre
low jitter was created by vre
Hello.
What hardware has very low jitter for base thread?
For example to low to be able generate 200-500khz step-dir at base thread.
Is that impossible?
  • Moderator
  • Moderator
20 Nov 2022 11:40 #257155 by tommylight
Replied by tommylight on topic low jitter
No, 200 to 500kHz is to much for a parallel port.
Also the step time and space at such a rate is to short for all cheap drives.
Parallel can do up to 50kHz if lucky with finding a PC, max i could do so far was around 70kHz.
Just in case, get a Mesa 5i25 or 6i25 or 7i92, those do 10MHz and have equivalent of 2 parallel ports, 34 pins and each can be an input or output.
Also, 7i80 has 4 parallel ports and can still be found.
Not very sure about the last one, so please do check.
21 Nov 2022 05:37 - 21 Nov 2022 05:40 #257194 by vre
Replied by vre on topic low jitter
What pc can do 70khz from parallel port ?
Yes mesa can do 10Mhz but in servo thread not in base thread.
Because i need to do raster engraving searching some hardware
that can get low jitter in base thread.
No parallel port... something other maybe
Last edit: 21 Nov 2022 05:40 by vre.
  • Moderator
  • Moderator
21 Nov 2022 11:23 #257201 by tommylight
Never tried, but i am pretty sure you can do raster with servo thread, it is updated 1000 times a second, should be enough.
I build small engravers/scratchers that use PWM to control head pressure, with parallel port, but the max speed is 3 meters per minute, so even 100000ns base period is enough.
I wonder why would you need 500kHz?
An old Fujitsu-Siemens workstation did 70kHz, it was a dual 4 core Xeon, it died! Later found out the 700W power supply had dry capacitors.
  • Moderator
  • Moderator
21 Nov 2022 11:25 #257202 by tommylight
Almost forgot, some Mesa boards can easily do 250000ns servo period, so that is 4000 updates per second.
21 Nov 2022 12:09 - 21 Nov 2022 12:11 #257205 by rodw
Replied by rodw on topic low jitter
In v 2.9, there is a new hal data type called hal_port but its not fully described as the examples are missing.
Docs: linuxcnc.org/docs/devel/html/man/man3/hal_port.3hal.html
It is designed to stream raster data to a laser in real time.
The elusive examples:
github.com/DuttonIndustrial/linuxcnc/tre...nfigs/sim/axis/laser
github.com/DuttonIndustrial/linuxcnc/blo...ents/laserpower.comp
github.com/DuttonIndustrial/linuxcnc/blo...mponents/raster.comp
Last edit: 21 Nov 2022 12:11 by rodw.
21 Nov 2022 12:13 #257206 by rodw
I think the objective is to buffer data to the mesa card and let the FGPA paint the data much faster than the linuxcnc servo thread can.
05 Dec 2022 23:31 #258636 by vre
Very usefull links.
Seems not included in 2.9 yet
06 Dec 2022 02:05 #258657 by andypugh
Replied by andypugh on topic low jitter
I think that HAL_PORT is in 2.9 but some new laser-related content has only gone in to master (and only just now, as I was waiting for CI to check it, and then git distracted)
github.com/LinuxCNC/linuxcnc/pull/2171
Moderators: PCW, jmelson
Time to create page: 1.332 seconds
