Mesa 7i77 not working after switching 7i96 to 7i96s
22 Nov 2022 14:21 #257335 by markkram
Hello, I'm pretty new to this whole LinuxCNC thing so please be patient if I don't know a lot.
After my 7i96 broke, I replaced it with a 7i96s due to supply. I then updated mesaflash and linuxcnc from 2.8.3 to 2.8.4 and quickly threw together a configuration with pncconf to check if the card was detected. Until then everything seemed fine, but after connecting the 7i77, none of the doughtercard pins like hm2_7i69s.0.7i77.0.0.input-XX were found. Also CR16 is on permanently.
So to make it short, even though everything is connected like before, nothing seems to recognize the 7i77. Can someone tell me where to look for errors? I'm out of ideas.
Thanks a lot in advance,
Mark
22 Nov 2022 14:41 #257338 by PCW
Does the 7I77 have 5V power?
22 Nov 2022 15:02 #257342 by markkram
Yes, CR1,3,5,7 are on
22 Nov 2022 15:37 #257343 by PCW
What happened to the 7I96?, it is possible the 7I77 was damaged
at the same time?
I can try that board combination later today to verify that there are no
firmware issues
22 Nov 2022 15:53 #257344 by markkram
I switched out the 7i77 as well, sorry I forgot to mention that.
22 Nov 2022 16:14 - 22 Nov 2022 19:38 #257346 by PCW
7I77 W4 and W12 in left hand position?
Also what is the LinuxCNC startup printout?
(Best done by starting LinuxCNC in a terminal window)
Edit: Tested 7I96S+7I77 with 7i96s_7i77d.bit firmware and it works correctly
so the problem is likely specific to your setup. Could be a bad card or cable
or some kind of more global issue.
Last edit: 22 Nov 2022 19:38 by PCW.
23 Nov 2022 13:37 #257471 by markkram
Thanks a lot for testing the setup!
W4 and W12 are in left hand position. After starting Linuxcnc from terminal, I get the following (I don't know if you meant this with startup printout, I'm really new to Linux):
Warning: Spoiler!
23 Nov 2022 15:25 - 23 Nov 2022 15:29 #257480 by PCW
It appears that the 7I96S has stock firmware loaded, not firmware to support a 7I77.
To install 7I77 compatible firmware. you would run these mesaflash commands:
mesaflash --device 7i96s --addr[the 7i96s ip address] --write 7i96s_7i77d.bin
mesaflash --device 7i96s --addr[the 7i96s ip address] --reload
The last command can be skipped by power cycling the 7I96S which does a reload
The first command assumes that you are running mesaflash from a directory that
contains the 7I96S configuration files.
Last edit: 23 Nov 2022 15:29 by PCW. Reason: clarify
The following user(s) said Thank You: markkram
05 Dec 2022 12:13 #258582 by markkram
That worked, thanks a lot!
Moderators: PCW, jmelson
Time to create page: 0.242 seconds
