Mesa 7i77 not working after switching 7i96 to 7i96s
3 years 11 months ago #257335 by markkram
Hello, I'm pretty new to this whole LinuxCNC thing so please be patient if I don't know a lot.
After my 7i96 broke, I replaced it with a 7i96s due to supply. I then updated mesaflash and linuxcnc from 2.8.3 to 2.8.4 and quickly threw together a configuration with pncconf to check if the card was detected. Until then everything seemed fine, but after connecting the 7i77, none of the doughtercard pins like hm2_7i69s.0.7i77.0.0.input-XX were found. Also CR16 is on permanently.
So to make it short, even though everything is connected like before, nothing seems to recognize the 7i77. Can someone tell me where to look for errors? I'm out of ideas.
Thanks a lot in advance,
Mark
3 years 11 months ago #257338 by PCW
Does the 7I77 have 5V power?
3 years 11 months ago #257342 by markkram
Yes, CR1,3,5,7 are on
3 years 11 months ago #257343 by PCW
What happened to the 7I96?, it is possible the 7I77 was damaged
at the same time?
I can try that board combination later today to verify that there are no
firmware issues
3 years 11 months ago #257344 by markkram
I switched out the 7i77 as well, sorry I forgot to mention that.
3 years 11 months ago - 3 years 11 months ago #257346 by PCW
7I77 W4 and W12 in left hand position?
Also what is the LinuxCNC startup printout?
(Best done by starting LinuxCNC in a terminal window)
Edit: Tested 7I96S+7I77 with 7i96s_7i77d.bit firmware and it works correctly
so the problem is likely specific to your setup. Could be a bad card or cable
or some kind of more global issue.
Last edit: 3 years 11 months ago by PCW.
Moderators: PCW, jmelson
Time to create page: 0.192 seconds
