Mesa 7i77 not working after switching 7i96 to 7i96s
3 years 11 months ago #257471 by markkram
Thanks a lot for testing the setup!
W4 and W12 are in left hand position. After starting Linuxcnc from terminal, I get the following (I don't know if you meant this with startup printout, I'm really new to Linux):
Warning: Spoiler!
3 years 11 months ago - 3 years 11 months ago #257480 by PCW
It appears that the 7I96S has stock firmware loaded, not firmware to support a 7I77.
To install 7I77 compatible firmware. you would run these mesaflash commands:
mesaflash --device 7i96s --addr[the 7i96s ip address] --write 7i96s_7i77d.bin
mesaflash --device 7i96s --addr[the 7i96s ip address] --reload
The last command can be skipped by power cycling the 7I96S which does a reload
The first command assumes that you are running mesaflash from a directory that
contains the 7I96S configuration files.
Last edit: 3 years 11 months ago by PCW. Reason: clarify
The following user(s) said Thank You: markkram
3 years 10 months ago #258582 by markkram
That worked, thanks a lot!
Moderators: PCW, jmelson
Time to create page: 0.095 seconds
