Mesa 7i96s a little jitter
3 years 11 months ago #257884 by An
Replied by An on topic Mesa 7i96s a little jitter
Hi Tommy totally understand why you put that there and I for one appreciate it! I just wanted to make sure I wasn’t going to fall into the trap seen as I already followed your very helpful guide… so to round this off along with adding ‘ethtool -C eno1 rx-usecs 0’ which I have now done I should also do as JT says and disable RX IRQ coalescing? Thanks again for taking the time to help.
3 years 11 months ago #257887 by tommylight
First check how it does now, then decide if you need to add that.
The following user(s) said Thank You: An
3 years 11 months ago #257902 by An
Sorry one more thing. When I entered ethtool -C eno1 rx-usecs 0 into command line it just went to another command line without any additional info - is there a command to check that this has actually achieved what was intended?
3 years 11 months ago #257905 by tommylight
No info usually means all is OK.
check with
ethtool -c eno1
3 years 11 months ago #257911 by PCW
Replied by PCW on topic Mesa 7i96s a little jitter
You can also just re-enter (up arrow)
and ethtool will complain that it's already set...
The following user(s) said Thank You: BigJohnT, tommylight, An
3 years 11 months ago #258033 by An
Hi all, so I have tried the mesa with the added command line of ethtool -C eno1 rx-usecs 0. The ping reports an avg of 0.128ms vs 0.305ms so good improvement. When I run halscope now things look better however not as good as that which pcw generated. I have 2 questions. I seem to have to run the ethtool command everytime the pc is restarted - is there a way to make the change permanent?
Second question - to disable Irq coalesce I plan to follow the guide and edit the etc network interface file - should I be following it exactly? (Seen as I have already set up using the ‘network manager way’). Sorry about the questions but Linux is completely foreign to me.
Thankyou!
Moderators: PCW, jmelson
Time to create page: 0.205 seconds
