Firmware for 7I92 and 7I36 or 7I48?
01 Dec 2022 23:50 #258272 by SupplySergeant
Firmware for 7I92 and 7I36 or 7I48? was created by SupplySergeant
A friend needs to get a lathe running really soon. It has an Anilam 4200T control that isn't behaving, and he want to switch to Linuxcnc. In looking at what is out there to drive the analog servo drives on his lathe, I see the only in-stock solutions look to be the 7I36 or 7I48. I have a 7I92 he can use, but I don't see a firmware for that combo. Any help in how to procede would be great, thanks!
02 Dec 2022 00:16 #258275 by PCW
Replied by PCW on topic Firmware for 7I92 and 7I36 or 7I48?
We should have 7I77s available in a couple weeks
7I36 and 7I48s require a 50 pin FPGA card
The following user(s) said Thank You: SupplySergeant
02 Dec 2022 00:33 #258277 by SupplySergeant
Replied by SupplySergeant on topic Firmware for 7I92 and 7I36 or 7I48?
I totally missed this part "7I36 and 7I48s require a 50 pin FPGA card"!
He has a job for the lathe that can't wait a few weeks, unfortunately. Is there any in stock combo that will run two axis of analog servos, and the spindle vfd?
02 Dec 2022 00:59 #258278 by jmelson
Replied by jmelson on topic Firmware for 7I92 and 7I36 or 7I48?
Another option is the Pico Systems PPMC for analog servo drives. There is an encoder card, a DAC card and a DIO card, you can plug in more cards if you need more functions. The encoder and DAC cards support 4 axes each. We have assembled boards and just have to put together the card cages and test. We can deliver these in a few days after order.
02 Dec 2022 01:21 #258280 by SupplySergeant
I'll check it out, thanks
02 Dec 2022 01:51 #258282 by PCW
We also a couple 7i77 test fallouts that are likely repairable
if you are in more of a hurry.
02 Dec 2022 02:33 #258287 by SupplySergeant
I'll get back to you on that tomorrow. He is currently chasing signals with an oscilloscope, it may be a bad encoder or cable. If so, the time constraint goes away and he can convert when stuff is a bit easier to acquire!
02 Dec 2022 14:39 #258320 by andypugh
Replied by andypugh on topic Firmware for 7I92 and 7I36 or 7I48?
I looked on the Mesa web site yesterday and there were 5i24 and 7i36 available. Those should work together, assuming that there is a firmware.
02 Dec 2022 16:17 #258326 by SupplySergeant
Well, turned out to be a shorted encoder. He is up and running, but is now planning to rebuild to Linuxcnc as soon as the current run of parts is done. So, I will watch Mesanet for 7i77's to come in stock! Thanks for the help, I appreciate it all!
Moderators: PCW, jmelson
Time to create page: 0.134 seconds
