- Hardware & Machines
- Driver Boards
- My on board VGA port not working while mesa PCI card is installed in pci port
- yrsiddhapura
- Thank you received: 5
08 Dec 2022 06:32 - 08 Dec 2022 12:43 #258872
by yrsiddhapura
My on board VGA port not working while mesa PCI card is installed in pci port was created by yrsiddhapura
Hello everyone greetings!!!!
My on board VGA port not working while mesa PCI 5i25-25 card is installed in pci port when remove it vga port gives signal. is mine card is dead or mother board damaged ? It was working perfectly but when I plug some connector to 7i52 it have pulled some 5i24 legs from pci slot.
Update !! Solved
Update !! Solved
Last edit: 08 Dec 2022 12:43 by yrsiddhapura.
- Thank you received: 7491
10 Dec 2022 20:49 #259133
Replied by tommylight on topic My on board VGA port not working while mesa PCI card is installed in pci port
Just wanted to reply with some testing ides and saw it is already solved.
How? What? Why? When?
The following user(s) said Thank You: yrsiddhapura
- yrsiddhapura
11 Dec 2022 04:05 #259178
by yrsiddhapura
Replied by yrsiddhapura on topic My on board VGA port not working while mesa PCI card is installed in pci port
Well i reset CMOS battery and cleared ram as mentioned in mother board manual.
- yrsiddhapura
11 Dec 2022 04:09 #259179
by yrsiddhapura
But still your idea is worthy for me you could share it.
11 Dec 2022 16:22 #259197
Probably they were both using the same IRQ.
Setting IRQ's to manual in BIOS usually fixes that.
- yrsiddhapura
11 Dec 2022 17:22 #259201
by yrsiddhapura
Thanks for sharing i will keep.in.mind if it happens again I would like to go with IRQ method.
- Driver Boards
Time to create page: 0.215 seconds
