Multiple Daugherboards on one Smart Serial Port?
  • HansU
  • HansU's Avatar Topic Author
  • Platinum Member
  • Platinum Member
14 Dec 2022 20:56 #259503 by HansU
Everywhere in the docs it is described that it is possible to connect up to 8 remote serial daughter cards to one smart serial port.
But how? There is no jumper on those boards to select the address.
Maybe the parameter NVUNITNUMBER (Non-volatile unit number) or UNITNUMBER (Working unit number) has to be set?
And how to connect the devices? Daisy chaining?
14 Dec 2022 22:07 #259507 by PCW
You can only have one remote device per serial channel.
A port is a sserial host controller which may have from 1 to 8 channels
Up to 4 sserial ports may be present in a single configuration
  • HansU
  • Platinum Member
  • Platinum Member
15 Dec 2022 06:59 #259541 by HansU
So a channel corresponds to a physical RS-422 connection?
And a port corresponds to a driver instance or in other words to a mesa card?
15 Dec 2022 12:11 #259555 by JT
A 7i74 gives you 8 smart serial ports
mesaus.com/product/7i74/
JT
  • HansU
  • Platinum Member
  • Platinum Member
15 Dec 2022 12:18 #259556 by HansU
JT
According to my understanding this gives me 8 Smart Serial channels. So I can connect up to 8 daughter boards.
15 Dec 2022 14:55 #259559 by PCW
A port corresponds to a controller instance in a FPGA card
There can be up to four controller instances in one FPGA card.
Each port can have 1..8 channels.
HAL Identifiers include the port and channel number, for example:
hm2_7i96s.0.7i87.P.C.analogin1
Where P is the port number and C is the channel number.
The following user(s) said Thank You: tommylight, HansU, JT
15 Dec 2022 18:44 #259569 by JPL
I think what is really confusing us is the fact that each channel are RS422/485, which is known to be multi-drop, thus allowing to connect multiple devices to a single communication channel (by definition). Now, PCW specifically mentioned that "You can only have one remote device per serial channel" for the mesa card, thus allowing only ONE connection per channel.
I would be tempted to now ask why, although I would guess it is some hardware limitation since the 'ports' are emulated in the case of the mesa card and are not 'real' hardware ports.
  • HansU
  • Platinum Member
  • Platinum Member
15 Dec 2022 21:02 #259584 by HansU
Ok now I got it. Thanks for clarifying. Maybe I should make the documentation more specific at this point.
15 Dec 2022 21:05 - 15 Dec 2022 21:13 #259586 by PCW
The reasons for using one device per port are speed and timing related
and the better electrical specifications of full duplex RS-422 links
vs RS-485 links.
(because there is no undriven state that requires micky-mouse termination schemes)
Last edit: 15 Dec 2022 21:13 by PCW.
The following user(s) said Thank You: JPL
Moderators: PCW, jmelson
Time to create page: 0.156 seconds
