Mesa 7I96S + 7I85S Bitfile
3 years 10 months ago #259682 by PCW
Replied by PCW on topic Mesa 7I96S + 7I85S Bitfile
Actually this is my fault, the correct firmware file is
7i96s_7i85sd.bin
(not .bit)
This is in the
hostmot2/configs/
subdirectory
3 years 10 months ago #259686 by Stefan321
ha ok, I've often fallen over the bin files. When I open the appropriate pin file, I unfortunately notice that the config is for 4 axes and 2 encoders. do i see that correctly plus 1 rs tx. As for the 7I85S.
I need 3 axes and 3 encoders on the 7I85S. is there also a suitable config?
because I would like to bring my milling spindle encoder back and then an xyz glass scale.
the milling spindle is a servo that i would like to control via step dir.
and thanks for the help
3 years 10 months ago #259688 by Stefan321
which I still don't quite understand. when i try to create a bin file myself in ise 14.7, it always tells me error in synthesize? even if i try other packets from other mesa cards
3 years 10 months ago - 3 years 10 months ago #259691 by PCW
The 7i96s_7i85sd.bin configuration has:
9 step/dir channels (5 on 7I96 and 4 on 7I85S)
2 sserial channels (1 on 7I96S and 1 on 7I85S)
5 encoders (1 on 7I96s and 4 on 7I85S)
Note that the encoders are multiplexed so each interface pin
supports 2 encoder pins.
The 7I96S uses an Efinix FPGA so you would need the
Efinix tool chain to make firmware for the 7i96S.
Last edit: 3 years 10 months ago by PCW.
3 years 10 months ago #259693 by Stefan321
First of all, that sounds even better than what I wanted, and secondly, I don't quite understand the thing about the pins. I also have old Heidenhein glass scales that I believe are the difference and not ttl. is it also possible to mix?
the glass scales have 8 pins, 2 of which are for 5v and gnd.
3 years 10 months ago #259696 by PCW
Yes, the 7I85S can interface to 4 encoders, individually selectable
as TTL or differential.
Moderators: PCW, jmelson
Time to create page: 0.283 seconds
