Ask - 7i96_7i74d.bin
  • zz912
  • zz912's Avatar Topic Author
  • Platinum Member
  • Platinum Member
27 Dec 2022 15:56 #260402 by zz912
Ask - 7i96_7i74d.bin was created by zz912
Helllo,
Can I ask for firmware 7i96_7i74d.bin ?
For new card 7i96s this firmware exist, but for old 7i96 not.
zz912
27 Dec 2022 16:43 #260409 by PCW
Replied by PCW on topic Ask - 7i96_7i74d.bin
File Name: 7i96_7i74d.zip
File Size:121 KB
The following user(s) said Thank You: zz912
  • zz912
  • Platinum Member
  • Platinum Member
27 Dec 2022 16:58 #260413 by zz912
Replied by zz912 on topic Ask - 7i96_7i74d.bin
Wow, that was speed. Thanks thanks.
  • zz912
  • Platinum Member
  • Platinum Member
27 Dec 2022 17:42 #260417 by zz912
Hello,
I have bad news. I tried flash.
jarda@CNC1:~$ mesaflash
Mesaflash version 3.4.6
Configuration and diagnostic tool for Mesa Electronics PCI(E)/ETH/EPP/USB/SPI boards
Try 'mesaflash --help' for more information
jarda@CNC1:~$ sudo mesaflash --device 7i96 --addr 10.10.10.10 --readhmid
[sudo] heslo pro jarda:
Configuration Name: HOSTMOT2
  BoardName : MESA7I96
  FPGA Size: 9 KGates
  FPGA Pins: 144
  Number of IO Ports: 3
  Width of one I/O port: 17
  Clock Low frequency: 100.0000 MHz
  Clock High frequency: 200.0000 MHz
  IDROM Type: 3
  Instance Stride 0: 4
  Instance Stride 1: 64
  Register Stride 0: 256
  Register Stride 1: 256
Modules in configuration:
  Module: DPLL
  There are 1 of DPLL in configuration
  Version: 0
  Registers: 7
  BaseAddress: 7000
  ClockFrequency: 100.000 MHz
  Register Stride: 256 bytes
  Instance Stride: 4 bytes
  Module: WatchDog
  There are 1 of WatchDog in configuration
  Version: 0
  Registers: 3
  BaseAddress: 0C00
  Module: IOPort
  There are 3 of IOPort in configuration
  Version: 0
  Registers: 5
  BaseAddress: 1000
  Module: StepGen
  There are 5 of StepGen in configuration
  Version: 2
  Registers: 10
  BaseAddress: 2000
  Module: QCount
  There are 1 of QCount in configuration
  Version: 2
  Registers: 5
  BaseAddress: 3000
  Module: SSerial
  There are 1 of SSerial in configuration
  Version: 0
  Registers: 6
  BaseAddress: 5B00
  Instance Stride: 64 bytes
  Module: SSR
  There are 1 of SSR in configuration
  Version: 0
  Registers: 2
  BaseAddress: 7D00
  Module: LED
  There are 1 of LED in configuration
  Version: 0
  Registers: 1
  BaseAddress: 0200
Configuration pin-out:
IO Connections for TB3 -> 7I96_0
Pin#                  I/O   Pri. func    Sec. func        Chan     Sec. Pin func   Sec. Pin Dir
TB3-1                   0   IOPort       None
TB3-2                   1   IOPort       None
TB3-3                   2   IOPort       None
TB3-4                   3   IOPort       None
TB3-5                   4   IOPort       None
TB3-6                   5   IOPort       None
TB3-7                   6   IOPort       None
TB3-8                   7   IOPort       None
TB3-9                   8   IOPort       None
TB3-10                  9   IOPort       None
TB3-11                 10   IOPort       None
TB3-13,14              11   IOPort       SSR              0        Out-00          (Out)
TB3-15,16              12   IOPort       SSR              0        Out-01          (Out)
TB3-17,18              13   IOPort       SSR              0        Out-02          (Out)
TB3-19,20              14   IOPort       SSR              0        Out-03          (Out)
TB3-21,22              15   IOPort       SSR              0        Out-04          (Out)
TB3-23,24              16   IOPort       SSR              0        Out-05          (Out)
IO Connections for TB1/TB2 -> 7I96_1
TB1-2,3                17   IOPort       StepGen          0        Step/Table1     (Out)
TB1-4,5                18   IOPort       StepGen          0        Dir/Table2      (Out)
TB1-8,9                19   IOPort       StepGen          1        Step/Table1     (Out)
TB1-10,11              20   IOPort       StepGen          1        Dir/Table2      (Out)
TB1-14,15              21   IOPort       StepGen          2        Step/Table1     (Out)
TB1-16,17              22   IOPort       StepGen          2        Dir/Table2      (Out)
TB1-20,21              23   IOPort       StepGen          3        Step/Table1     (Out)
TB1-22,23              24   IOPort       StepGen          3        Dir/Table2      (Out)
TB2-2,3                25   IOPort       StepGen          4        Step/Table1     (Out)
TB2-4,5                26   IOPort       StepGen          4        Dir/Table2      (Out)
TB2-7,8                27   IOPort       QCount           0        Quad-A          (In)
TB2-10,11              28   IOPort       QCount           0        Quad-B          (In)
TB2-13,14              29   IOPort       QCount           0        Quad-IDX        (In)
TB2-16,17              30   IOPort       SSerial          0        RXData0         (In)
TB2-18,19              31   IOPort       SSerial          0        TXData0         (Out)
Internal-TXEn          32   IOPort       SSerial          0        TXEn0           (Out)
Internal               33   IOPort       SSR              0        AC Ref          (Out)
IO Connections for P1 -> 7I96_2
P1-01/DB25-01          34   IOPort       None
P1-02/DB25-14          35   IOPort       None
P1-03/DB25-02          36   IOPort       None
P1-04/DB25-15          37   IOPort       None
P1-05/DB25-03          38   IOPort       None
P1-06/DB25-16          39   IOPort       None
P1-07/DB25-04          40   IOPort       None
P1-08/DB25-17          41   IOPort       None
P1-09/DB25-05          42   IOPort       None
P1-11/DB25-06          43   IOPort       None
P1-13/DB25-07          44   IOPort       None
P1-15/DB25-08          45   IOPort       None
P1-17/DB25-09          46   IOPort       None
P1-19/DB25-10          47   IOPort       None
P1-21/DB25-11          48   IOPort       None
P1-23/DB25-12          49   IOPort       None
P1-25/DB25-13          50   IOPort       None
jarda@CNC1:~$ pwd
/home/jarda
jarda@CNC1:~$ ls
Dokumenty  linuxcnc            linuxcnc_print.txt  Plocha   Šablony  Videa
Hudba      linuxcnc_debug.txt  Obrázky             Stažené  Veřejné
jarda@CNC1:~$ cd linuxcnc/
jarda@CNC1:~/linuxcnc$ ls
configs  linuxcnc-2.8  Mesa-firmware  nc_files
jarda@CNC1:~/linuxcnc$ cd Mesa-firmware/
jarda@CNC1:~/linuxcnc/Mesa-firmware$ ls
7i96  7i96s
jarda@CNC1:~/linuxcnc/Mesa-firmware$ cd 7i96
jarda@CNC1:~/linuxcnc/Mesa-firmware/7i96$ ls
configs
jarda@CNC1:~/linuxcnc/Mesa-firmware/7i96$ cd configs/
jarda@CNC1:~/linuxcnc/Mesa-firmware/7i96/configs$ ls
hostmot2
jarda@CNC1:~/linuxcnc/Mesa-firmware/7i96/configs$ cd hostmot2/ ls
bash: cd: příliš mnoho argumentů
jarda@CNC1:~/linuxcnc/Mesa-firmware/7i96/configs$ cd hostmot2/ |ls
hostmot2
jarda@CNC1:~/linuxcnc/Mesa-firmware/7i96/configs/hostmot2$ ls
PIN_7I96_7I74D_51.vhd  7i96d_1pwm.pin     7i96_inmd.pin        7i96_5abob_inmd.bit  7i96_7i77d.bit
source                 7i96_fallback.bit  7i96_inm_7i85sd.bit  7i96_5abob_inmd.pin  7i96_7i78d.bit
7i96d.bit              7i96_fallback.pin  7i96_pktd.bit        7i96_6enc_d.bit      7i96_7i78d.pin
7i96d.pin              7i96_g540dpl.bit   7i96_pktd.pin        7i96_6enc_d.pin      7i96_7i85d.bit
7i96dpl.bit            7i96_inmd.bit      7i96_p1inmd.bit      7i96_7i74d.bit       7i96_7i85sd.bit
7i96_dsti.bit          7i96_inmd_dp.bit   7i96_5abob_d.bit     7i96_7i76d.bit       7i96_7i85sinmd.bit
7i96d_1pwm.bit         7i96_inmd_dp.pin   7i96_5abob_d.pin     7i96_7i76d.pin       7i96_7i89d.bit
jarda@CNC1:~/linuxcnc/Mesa-firmware/7i96/configs/hostmot2$ sudo mesaflash --device 7i96 --addr 10.10.10.10 --write 7i96_7i74d.bit
Checking file... OK
  File type: Xilinx bit file
Boot sector OK
FLASH memory sectors to write: 6, max sectors in area: 16
Erasing FLASH memory sectors starting from 0x100000...
  |EEEEE
Process stuck and LED IN1 is flashing.
I am waiting over 10 minutes. What should I do now? CTRL+C ?
27 Dec 2022 17:53 #260418 by PCW
Yes control C and retry
  • zz912
  • Platinum Member
  • Platinum Member
27 Dec 2022 18:08 #260419 by zz912
Good news. I tried it again and it works:
jarda@CNC1:~/linuxcnc/Mesa-firmware/7i96/configs/hostmot2$ sudo mesaflash --device 7i96 --addr 10.10.10.10 --readhmid
  FPGA Size: 9 KGates
  FPGA Pins: 144
  IDROM Type: 3
  Module: DPLL
  Version: 0
  Registers: 7
  BaseAddress: 7000
  Module: WatchDog
  Version: 0
  Registers: 3
  BaseAddress: 0C00
  Module: IOPort
  Version: 0
  Registers: 5
  BaseAddress: 1000
  Module: StepGen
  Version: 2
  Registers: 10
  BaseAddress: 2000
  Module: QCount
  Version: 2
  Registers: 5
  BaseAddress: 3000
  Module: SSerial
  Version: 0
  Registers: 6
  BaseAddress: 5B00
  Module: SSR
  Version: 0
  Registers: 2
  BaseAddress: 7D00
  Module: LED
  Version: 0
  Registers: 1
  BaseAddress: 0200
TB3-1                   0   IOPort       None
TB3-2                   1   IOPort       None
TB3-3                   2   IOPort       None
TB3-4                   3   IOPort       None
TB3-5                   4   IOPort       None
TB3-6                   5   IOPort       None
TB3-7                   6   IOPort       None
TB3-8                   7   IOPort       None
TB3-9                   8   IOPort       None
P1-01/DB25-01          34   IOPort       SSerial          0        RXData1         (In)
P1-02/DB25-14          35   IOPort       SSerial          0        RXData2         (In)
P1-03/DB25-02          36   IOPort       SSerial          0        RXData3         (In)
P1-04/DB25-15          37   IOPort       SSerial          0        RXData4         (In)
P1-05/DB25-03          38   IOPort       SSerial          0        TXData1         (Out)
P1-06/DB25-16          39   IOPort       SSerial          0        TXData2         (Out)
P1-07/DB25-04          40   IOPort       SSerial          0        TXData3         (Out)
P1-08/DB25-17          41   IOPort       SSerial          0        TXData4         (Out)
P1-09/DB25-05          42   IOPort       SSerial          0        RXData5         (In)
P1-11/DB25-06          43   IOPort       SSerial          0        RXData6         (In)
P1-13/DB25-07          44   IOPort       SSerial          0        RXData7         (In)
P1-17/DB25-09          46   IOPort       SSerial          0        TXData5         (Out)
P1-19/DB25-10          47   IOPort       SSerial          0        TXData6         (Out)
P1-21/DB25-11          48   IOPort       SSerial          0        TXData7         (Out)
Thank you.
27 Dec 2022 18:12 #260420 by PCW
Yes, you may have a 5V power issue if it stops mid-programming.
Luckily the fallback (blinking light) allows recovery
The following user(s) said Thank You: tommylight, zz912
  • zz912
  • Platinum Member
  • Platinum Member
27 Dec 2022 18:24 #260421 by zz912
I dont need it, but I have question.
Physical:
7i96 have 1 RX/TX
7i74 have 8 RX/TX
but in firmware 7i96_7i74d.bin
7i96 use 1 RX/TX
7i74 use "only 7" RX/TX
Is it intentional?
27 Dec 2022 18:30 #260422 by PCW
Yes, the 7I96 FPGA cannot fit 2 instances of sserial ports, so only one instance
is present. Since each port has a maximum of 8 channels, and since the sserial
channel on the 7I96 is used, there are only 7 channels free.
The 7I96S has a larger FPGA so it has 2 sserial ports:
Port 0 with 1 channel on the 7I96S
Port 1 with 8 channels on the 7I74.
  • zz912
  • Platinum Member
  • Platinum Member
27 Dec 2022 18:45 #260423 by zz912
You're probably right about the source. We have a temporary source there now. It should be 2A. But the voltage on it is only 4.82V and there is only Mesa 7i96 on it.
Moderators: PCW, jmelson
Time to create page: 0.107 seconds
