Trinamic TMCM-351 as a CNC controller & driver
- theron
27 Dec 2022 16:07 #260404
by theron
Trinamic TMCM-351 as a CNC controller & driver was created by theron
Hi there,
I recently got give an Trinamic TMCM-351 motor controller and driver module and was hopeful it would be possible to use it as a CNC controller with something like LinuxCNC.
Does anyone have experience with Trinamic motion controllers and LinuxCNC?
- vre
- Thank you received: 17
29 Dec 2022 04:25 - 29 Dec 2022 04:29 #260495
by vre
Replied by vre on topic Trinamic TMCM-351 as a CNC controller & driver
not supported by linuxcnc...
For linuxcnc look something from mesa hardware or other compatible hardware.
But for simple steppers if you have low jitter will work the parallel port with cheap 5axis bob.
Last edit: 29 Dec 2022 04:29 by vre.
- theron
29 Dec 2022 16:12 #260501
by theron
Replied by theron on topic Trinamic TMCM-351 as a CNC controller & driver
Aww shucks, seemed like a good board.
Im sure it will get use on some project sometime.
I guess Ill go for the MESA 7C80 or 7C81 RPI
