mesa 7196s ethernet cable
- brianTruck
- Thank you received: 6
27 Dec 2022 22:47 - 27 Dec 2022 22:48 #260440
by brianTruck
mesa 7196s ethernet cable was created by brianTruck
Does the mesa 7i96s require a special ethernet cable? I just got mine and tried pinging it on 10.10.10.10 and user leds on the board flash but I get no response.
Last edit: 27 Dec 2022 22:48 by brianTruck.
- Thank you received: 5334
27 Dec 2022 23:08 #260445
Replied by PCW on topic mesa 7196s ethernet cable
Standard cable
What does ip a
report?
What does ip a
report?
The following user(s) said Thank You: brianTruck
- Thank you received: 7491
27 Dec 2022 23:13 #260446
Replied by tommylight on topic mesa 7196s ethernet cable
No it does not, even a 30 meter long cheap cable works, for a Plasma that does huge amounts of interference!
So, what does
ip a
in a terminal return?
Did you set the jumpers on the 7i96S for 10.10.10.10 as stated in the manual?
If possible, make sure the 5V supplied to Mesa board is actually measuring 5V, plenty small power supplies have lover voltage causing issues.
Since the LED's on the board react to ping, cable should be OK, but if the cable is DIY i would change it jus to be sure till everything is set up and working.
So, what does
ip a
- brianTruck
28 Dec 2022 01:09 #260450
by brianTruck
Replied by brianTruck on topic mesa 7196s ethernet cable
Had jumpers set wrong, good to go now.
Thank You!
Thank You!
Time to create page: 0.094 seconds
