7i96s with 7i76 & sserial device
30 Mar 2023 10:40 #267902 by Toto
Hello,
I have the same configuration (7i96s and 7i76 connected via DB25).
I download the firmware 7i96s_7i76d.bit on the 7i96s.
So I have the same problem, that it doesn't find the 7i76 pins.
I'm not sure how to configure it on PNCconf because I don't have the firmware 7i96s_7i76d.bit proposed on the firmware box.
I tried this topic but still doesn't show 7i76 pins.
30 Mar 2023 15:16 #267917 by PCW
If linuxCNC does not find 7I76 pins Its likely:
1. You don't have 2 sserial ports enabled in the sserial_port_0=nnxxxx configuration token
2, You are missing either 5V or field power on the 7I76
20 Apr 2023 12:13 - 20 Apr 2023 12:25 #269483 by Toto
Thank you for your answer. I was able to do some testing and found this:
-Without a serial port, I can see the 7I76 pins.
loadrt hm2_eth board_ip="10.10.10.10" config="num_encoders=0 num_pwmgens=0 num_stepgens=4"
But when I add a motion.digital output on the 7i96s output 0, I get a timeout error and linuxcnc doesn't launch.
net dispence-is-active <= motion.digital-out-00
net dispence-is-active => hm2_7i96s.0.ssr.00.out-00
-With a serial port, I don't see the 7I76 pins but I don't have an error with the motion digital.
loadrt hm2_eth board_ip="10.10.10.10" config="num_encoders=0 num_pwmgens=0 num_stepgens=4 sserial_port_0=0xxxxxxx"
I didn't find any ways to get both to work.
Last edit: 20 Apr 2023 12:25 by Toto.
20 Apr 2023 13:07 - 20 Apr 2023 15:07 #269487 by PCW
Note, with "sserial_port_0=0xxxxxxx" you have disabled all but one sserial channel
(the expansion channel on the 7I96S is the only enabled channel)
For a 7i96s_7i76d configuration you should enable all sserial ports with "sserial_port_0=ABCxxxxx"
Where ABC are the modes of sserial channels 0,1,2 respectively.
Last edit: 20 Apr 2023 15:07 by PCW. Reason: clarify
Moderators: PCW, jmelson
Time to create page: 0.276 seconds
