additional 24 outputs
08 Jan 2023 16:08 #261271 by mgm
additional 24 outputs was created by mgm
After I did not manage to control my two Festo valve terminals, I now have to come up with a different way to switch my 24 valves.
Shortly to my project:
I have 24 vacuum cups on my milling table which I want to activate individually. For this purpose I have 2 Festo cpv14 valve islands with 12 3/2 way mono stable each.
At the end there should be a TAB in Axis where my 24 suction cups should be displayed and I can activate with a click on a suction cup in.
I currently have the following components in use.
- 7i76ed with the bit file 7i76e_7i76x1_5abobpD
  the bit file is for the additional PWM's
- at P1 of the 7i76ed there is a 7i75 for my PWM's
- at the serial interface of the 7i76ed is a 7i84ed
  on which due to my wrong connection of the power only the
  half of the inputs and outputs are usable!
Now to my question:
is it possible to use the remaining IO pins with a 2nd 7i75 at the P2 of the 7i76ed for example to switch small 5V relays ?
Or does anyone have another idea how I can get additional 24 outputs?
08 Jan 2023 18:51 - 08 Jan 2023 18:53 #261295 by andypugh
Replied by andypugh on topic additional 24 outputs
7i75 (with an adaptor) should work on P2, possibly even with the existing bitfile. But you will only get 16 outputs.
A more expandable option would be the 7i74 and then one or more smart-serial boards.
Or, possibly replace your broken 7i84 with a 7i71 or 7i66 (if you don't need the inputs on the 7i84)
Last edit: 08 Jan 2023 18:53 by andypugh.
Moderators: PCW, jmelson
Time to create page: 0.098 seconds
