Mesa 7i77 - dead encoder channel
19 Jan 2023 08:50 #262394 by Henk
Mesa 7i77 - dead encoder channel was created by Henk
Hi
I have a Mesa 7i77 with a dead encoder channel number 5. I dont know why, but the card was new, and i installed it in a new retrofit project. Encoder 5 is the spindle encoder.
This machine has 6 encoders. all of them differential ABZ, 5v.
First, i suspected the encoder, so i wired a new one in. no luck
I then plugged the new encoder into the encoder 4 position in the card, and it works, plug it into no 5 position, not working
I changed the 7i77 with another new one and it worked. So i assume that the problem is with that 7i77.
I can repair it if i can find the defective component, and i would appreciate any pointers on what to look for, where to measure and so on. I have scope if required.
Henk
  • Moderator
  • Moderator
19 Jan 2023 12:27 #262408 by tommylight
Replied by tommylight on topic Mesa 7i77 - dead encoder channel
Wire the encoder, power the board, run LinuxCNC, on the Machine menu click on Show Hal Configuration, there on the right side click on Watch tab, them on the left side expand Pins, find the card 7i77, find encoders, on encoder 5 click on Encoder A and B pins.
Turn the encoder slowly and check on screen if both LEDs go on and off.
Also choose index if you intend on using it.
19 Jan 2023 13:43 #262414 by Henk
Replied by Henk on topic Mesa 7i77 - dead encoder channel
Hi.
that was the first thing I did. No luck
I'm positive that the card is faulty. Changed it with another 7i77 and it worked.
I did check the jumpers as well, although with a diff encoder, it will count if the jumpers are set for single ended as well.
19 Jan 2023 16:03 #262422 by PCW
Replied by PCW on topic Mesa 7i77 - dead encoder channel
If Neither A,B or index work, its likely the 26LS32 near the ENC 5 connector
20 Jan 2023 02:10 #262450 by Henk
I will set up the card on the bench and do some poking around.
Moderators: PCW, jmelson
Time to create page: 1.339 seconds
