7i92H cant get it work :(
- hitchhiker
- Thank you received: 21
21 Jan 2023 00:37 #262533
by hitchhiker
7i92H cant get it work :( was created by hitchhiker
Hello!
In the last days i got a used 7i92H..
my machine runs on a 6i25... i want to change to a 7i92H because my machine pc doesnt have pci slots.. only ethernet... its a optiplex 3020 micro form factor.
my problem is.. i cant find the 7i92.zip on the internet...for the 7i92h (old version)
next problem is.. i looked with mesaflash the pinouts.. all pins are i/o.
how can i now check the card and the pins working????
need some help please...
i can connect via ethernet and can read reload etc...
but in linuxcnc i cant see any change on any gpio...
- JPL
- Thank you received: 118
21 Jan 2023 02:36 - 21 Jan 2023 02:41 #262539
by JPL
Replied by JPL on topic 7i92H cant get it work :(
Last edit: 21 Jan 2023 02:41 by JPL.
- JPL
21 Jan 2023 02:46 #262540
by JPL
Also, for the manual, go to mesanet.com (not the store) , click on 'ANYTHING I/O FPGA CARDS' then scroll down. The 'old' 7i92 manual and software are still there.
- hitchhiker
21 Jan 2023 08:26 #262563
by hitchhiker
Replied by hitchhiker on topic 7i92H cant get it work :(
thanks i done this..
but..
i flash the 7i92_G540x2D.bit from the 7i92.zip file
restart the 7i92
open linuxcnc with a in pconfig maked linuxcnc ini ..
then i look at hal config.
pin1 is a i/o
give him gnd connection
the gpio does not change his state
same with pin 13 15 17 on port p2 and p1
uname -a:
Linux cnc 4.19.0-23-rt-amd64 #1 SMP PREEMPT RT Debian 4.19.269-1 (2022-12-20) x86_64 GNU/Linux.
what do i wrong?!
thanks
but..
restart the 7i92
pin1 is a i/o
uname -a:
what do i wrong?!
thanks
- Thank you received: 5334
21 Jan 2023 15:47 #262586
Replied by PCW on topic 7i92H cant get it work :(
How are you examining the hal pins?
If hal show, you must use the "WATCH" tab, not the "SHOW" tab
- hitchhiker
22 Jan 2023 17:45 #262664
by hitchhiker
the busswitch is the problem.. both are dead... all ports show red... and you can see on both busdrivers a small hole... cheap bought on ebay without return and varenty....
desolder the busdrivers and solder new in is the solution...
thanks
thanks
22 Jan 2023 18:52 #262671
Yeah, holes in the bus switches usually means something like 12/24V was applied to the inputs...
- hitchhiker
22 Jan 2023 18:58 #262672
by hitchhiker
sure! thats why the ebaydude was so friendly.... and his photos looks so good... but the photos done in a angle where you cant see the holes....
2 new bus switches and all is in the past....
Time to create page: 0.233 seconds
