7i80HD_16 setup
22 Jan 2023 09:01 #262649 by llimcombi
7i80HD_16 setup was created by llimcombi
Hi
I am currently chaning setup on my milling machine from mach3 to linuxcnc.
I have got most of the things sorted but have the spindle left.
To get the spindle to work i belive i need another bit file for my 7i80HD_16 that will change the last stepgen to pwmgen if this is possible to do.
Currently i have the (7i80hd_16_svst6_6_7i52sd.bit) loaded and seems to be working fine exept spindle.
Is there anyone that could help me to create such a bit file?
Same pin assignment as (7i80hd_16_svst6_6_7i52sd.bit) only change the chanel 5 as pwm/dir
Regards
22 Jan 2023 15:45 #262662 by PCW
Replied by PCW on topic 7i80HD_16 setup
File Name: 7i80_16_sv...52sd.zip
File Size:100 KB
The following user(s) said Thank You: llimcombi
Moderators: PCW, jmelson
Time to create page: 0.103 seconds
