Mesa 7i76e & 7i85 bitfile trouble
- Heisenberg
23 Jan 2023 20:39 #262766
by Heisenberg
Mesa 7i76e & 7i85 bitfile trouble was created by Heisenberg
I want to use my 7i76e with an 7i85 board. I´ve changed the IP address to 10.10.10.10 and I get access to the card.So far, so good.Then I used mesaflash command:The command was successfully, no errors Next command: But the prompted result shows no changes of the bitfile on the card. It look like before.
I used the tutorial from Peter / Talla83 to do this. Now I have some Questions:1) Which Bit file is correct for my combination?2) Are there any changes on the jumpers on the Mesa card to do? Especially with Jumper W9? Actually it is factory layout3) Can anybody of you help me with this? Thanks a lot!
Marcus
sudo mesaflash --device 7i76 --addr 10.10.10.10 --readhmidsudo mesaflash --device 7i76e --addr 10.10.10.10 -- fallback --write 7i76e_7i76x1_7i85x1D.bitsudo mesaflash --device 7i76e --addr 10.10.10.10 -- fallback – realoadsudo mesaflash --device 7i76e --addr 10.10.10.10 --readhmid
Configuration Name: HOSTMOT2
BoardName : MESA7I76
FPGA Size: 16 KGates
FPGA Pins: 256
Number of IO Ports: 3
Width of one I/O port: 17
Clock Low frequency: 100.0000 MHz
Clock High frequency: 200.0000 MHz
IDROM Type: 3
Instance Stride 0: 4
Instance Stride 1: 64
Register Stride 0: 256
Register Stride 1: 256
Modules in configuration:
Module: DPLL
There are 1 of DPLL in configuration
Version: 0
Registers: 7
BaseAddress: 7000
ClockFrequency: 100.000 MHz
Register Stride: 256 bytes
Instance Stride: 4 bytes
Module: WatchDog
There are 1 of WatchDog in configuration
Version: 0
Registers: 3
BaseAddress: 0C00
Module: IOPort
There are 3 of IOPort in configuration
Version: 0
Registers: 5
BaseAddress: 1000
Module: StepGen
There are 5 of StepGen in configuration
Version: 2
Registers: 10
BaseAddress: 2000
Module: QCount
There are 1 of QCount in configuration
Version: 2
Registers: 5
BaseAddress: 3000
Module: SSerial
There are 1 of SSerial in configuration
Version: 0
Registers: 6
BaseAddress: 5B00
Instance Stride: 64 bytes
Module: LED
There are 1 of LED in configuration
Version: 0
Registers: 1
BaseAddress: 0200
Configuration pin-out:
IO Connections for on-card -> 7I76
Pin# I/O Pri. func Sec. func Chan Sec. Pin func Sec. Pin Dir
TB2-4,5 0 IOPort StepGen 0 Dir/Table2 (Out)
TB2-2,3 1 IOPort StepGen 0 Step/Table1 (Out)
TB2-10,11 2 IOPort StepGen 1 Dir/Table2 (Out)
TB2-8,9 3 IOPort StepGen 1 Step/Table1 (Out)
TB2-16,17 4 IOPort StepGen 2 Dir/Table2 (Out)
TB2-14,15 5 IOPort StepGen 2 Step/Table1 (Out)
TB2-22,23 6 IOPort StepGen 3 Dir/Table2 (Out)
TB2-20,21 7 IOPort StepGen 3 Step/Table1 (Out)
TB3-4,5 8 IOPort StepGen 4 Dir/Table2 (Out)
TB3-2,3 9 IOPort StepGen 4 Step/Table1 (Out)
Internal-Field-IO 10 IOPort SSerial 0 TXData0 (Out)
Internal-Field-IO 11 IOPort SSerial 0 RXData0 (In)
TB3-18,19 12 IOPort SSerial 0 TXData1 (Out)
TB3-16,17 13 IOPort SSerial 0 RXData1 (In)
TB3-13,14 14 IOPort QCount 0 Quad-IDX (In)
TB3-10,11 15 IOPort QCount 0 Quad-B (In)
TB3-7,8 16 IOPort QCount 0 Quad-A (In)
IO Connections for P1
DB25 pin# I/O Pri. func Sec. func Chan Sec. Pin func Sec. Pin Dir
1 17 IOPort None
14 18 IOPort None
2 19 IOPort None
15 20 IOPort None
3 21 IOPort None
16 22 IOPort None
4 23 IOPort None
17 24 IOPort None
5 25 IOPort None
6 26 IOPort None
7 27 IOPort None
8 28 IOPort None
9 29 IOPort None
10 30 IOPort None
11 31 IOPort None
12 32 IOPort None
13 33 IOPort None
IO Connections for P2
1 34 IOPort None
14 35 IOPort None
2 36 IOPort None
15 37 IOPort None
3 38 IOPort None
16 39 IOPort None
4 40 IOPort None
17 41 IOPort None
5 42 IOPort None
6 43 IOPort None
7 44 IOPort None
8 45 IOPort None
9 46 IOPort None
10 47 IOPort None
11 48 IOPort None
12 49 IOPort None
13 50 IOPort None Marcus
- Thank you received: 5326
23 Jan 2023 20:51 #262767
Replied by PCW on topic Mesa 7i76e & 7i85 bitfile trouble
A reasonable command set would be:
mesaflash --device 7i76e --addr 10.10.10.10 --write 7i76e_7i76x1_7i85x1D.bit
mesaflash --device 7i76e --addr 10.10.10.10 --reload
The following user(s) said Thank You: Heisenberg
- Heisenberg
23 Jan 2023 21:05 #262768
by Heisenberg
Replied by Heisenberg on topic Mesa 7i76e & 7i85 bitfile trouble
Thank you!!!!
it works
it works
TB3-13,14 14 IOPort MuxedQCount 2 MuxQ-IDX (In)
TB3-10,11 15 IOPort MuxedQCount 2 MuxQ-B (In)
TB3-7,8 16 IOPort MuxedQCount 2 MuxQ-A (In)
1 17 IOPort SSerial 0 RXData6 (In)
14 18 IOPort SSerial 0 TXData6 (Out)
2 19 IOPort SSerial 0 RXData5 (In)
15 20 IOPort SSerial 0 TXData5 (Out)
3 21 IOPort SSerial 0 RXData4 (In)
16 22 IOPort SSerial 0 TXData4 (Out)
4 23 IOPort SSerial 0 RXData3 (In)
17 24 IOPort SSerial 0 TXData3 (Out)
5 25 IOPort SSerial 0 RXData2 (In)
6 26 IOPort SSerial 0 TXData2 (Out)
7 27 IOPort MuxedQCountSel 0 MuxSel0 (Out)
8 28 IOPort MuxedQCount 0 MuxQ-A (In)
9 29 IOPort MuxedQCount 0 MuxQ-B (In)
10 30 IOPort MuxedQCount 0 MuxQ-IDX (In)
11 31 IOPort MuxedQCount 1 MuxQ-A (In)
12 32 IOPort MuxedQCount 1 MuxQ-B (In)
13 33 IOPort MuxedQCount 1 MuxQ-IDX (In)
1 34 IOPort None
14 35 IOPorPlease Log in or Create an account to join the conversation.
