Mesa 7i71 not discovered
- Henk
- Thank you received: 92
31 Jan 2023 07:50 #263308
by Henk
Mesa 7i71 not discovered was created by Henk
HI
I have a brand new mesa 7i71, but it does not show up when i load the config.
my config is: 7i92 + 7i77 + 7i74 +7i73 +7i70 +7i71
All three sserial cards are connected to the 7i74. Verified all field voltages, and i made sure that i use the correct ports on the 7i74, changed ports, cables etc but no luck. The 7i73 and 7i70 is discovered so i bellieve i am loading the config correctly
I even connected the card in another machine that also use a 7i71 and there it is also nit discovered.
when i switch the power on (no switch, directly powered from switchmode psu's like i always do) Yellow CR9 is on and red CR33 is on. it stays like that when i load the config.
Any idea what i can do to find the problem?
henk
henk
- Thank you received: 7491
31 Jan 2023 11:41 #263340
Replied by tommylight on topic Mesa 7i71 not discovered
In the loadrt line with 7i92, set all serial ports to 0, so from 000xxx or whatever is there to 00000000.
Is there field power going to 7i71?
- Thank you received: 5334
31 Jan 2023 14:46 #263364
Replied by PCW on topic Mesa 7i71 not discovered
If you can swap the 7I71 with a working 7I71 and it is not discovered
(using the same power and serial cables as the working 7I71),
That most likely indicates that the new 7I71 is faulty
- Henk
31 Jan 2023 15:49 #263365
by Henk
Replied by Henk on topic Mesa 7i71 not discovered
Hi PCW.
That is exactly what I have done and concluded the same.
Is it worth trying to connect in setup mode over USB /rs232 and re flash it?
Have not done this before and only glanced over the doc once. Is there a more detailed procedure available?
31 Jan 2023 16:20 #263368
If the red light illuminates its unlikely that there is a firmware issue.
Seems more like serial communication problem
- Henk
31 Jan 2023 17:17 #263373
by Henk
Is it fixable?
31 Jan 2023 17:45 #263377
Fixable or replaceable under warranty
- Henk
01 Feb 2023 02:43 #263414
by Henk
The shipping is a bit expensive, but i will contact Mesa on email. thanks PCW
Time to create page: 0.203 seconds
