7i76 Spindle Output Not working
- Thank you received: 5334
17 Feb 2023 14:51 #264695
Replied by PCW on topic 7i76 Spindle Output Not working
OK so the output circuit is working
Note that negative spinout values are not legal
Can you post you hal/ini files?
- mloser
17 Feb 2023 17:57 #264706
by mloser
Replied by mloser on topic 7i76 Spindle Output Not working
I attached them:
17 Feb 2023 18:07 #264708
OK so the spindle command speed path is pretty complex
can you post the results of:
halcmd show all | grep spindle > spindle.txt
running that hal/ini configuration when you get an incorrect full scale output?
- mloser
17 Feb 2023 18:14 #264709
by mloser
My spindle controller supplies -12 volts and +12 volts.
Negative voltages turn the spindle CW.
Positive voltages turn the spindle CCW.
The more negative value is always fed to TB4 pin1 through a relay.
The more positive value is fed to TB4 pin3 through a relay.
(In case you are wondering about scale.spindle.Cw and scale.spindle.Ccw)
The gain of .004 is because 12 volts to spindle == 3000 rpm on motor
Thanks,
Mike
Thanks,
Mike
17 Feb 2023 18:37 #264712
Normally you would just do this scaling with the output scale value
(that is set the spindle output scale to 3000 so a spinout value of 3000
results in 12V or full scale)
I don't think its safe to switch TB4 PIN 1 and 3 unless you can guarantee
relay timing so you don't get a 24V transient across the pins.
A safer way is to use an isolated 12Vsupply always connected to TB4 pins 1,3
and switch the output polarity with a DPDT relay
- mloser
18 Feb 2023 01:11 #264735
by mloser
I ran
File "spindle.txt" is attached.
Thanks,
Mike
Thanks,
Mike
18 Feb 2023 03:26 #264737
Oops that's missing the parameters
halcmd show all | grep spin > spindle.txt
Should get everything
- mloser
18 Feb 2023 13:50 #264748
by mloser
"halcmd show all | grep spin > spindle.txt"
18 Feb 2023 15:57 #264755
These are reversed
26 float RW 0 hm2_5i25.0.7i76.0.3.spinout-maxlim
26 float RW 1800 hm2_5i25.0.7i76.0.3.spinout-minlim
With this setting:
26 float RW 1800 hm2_5i25.0.7i76.0.3.spinout-scalemax
You should get full output at when spinout is 1800
(you don't need the scale component)
Spinout should be fed from the absolute spindle speed in RPM (negative values are illegal)
(and any polarity reversing should only affect external connections)
With this setting:
- mloser
01 Mar 2023 03:29 #265631
by mloser
Thanks so much.
It's working great now!
Time to create page: 0.119 seconds
