7i95 availability
- zmrdko
- Thank you received: 49
13 Feb 2023 23:01 #264468
by zmrdko
7i95 availability was created by zmrdko
Hello,
does anybody know, when or if the 7i95 card will be available?
- zmrdko
13 Feb 2023 23:30 #264473
by zmrdko
Replied by zmrdko on topic 7i95 availability
or are there any other options.
I have seen somwhere here on forum, that it is possible to use NVEM cnc cards.
Is it true?
Is it true?
- Thank you received: 5334
13 Feb 2023 23:55 #264474
Replied by PCW on topic 7i95 availability
Yes, NVEM CNC controllers (with modified firmware) can be used with LinuxCNC.
If you need step/dir plus multiple high speed encoders (like the 7I95 has), the NVEM is probably not a good choice.
7I95Ts should be available in about 2 months and there may be protos available this month
If you need multiple encoders now, one option is a 7I96S+7I85S
( 4 additional encoders) or 7I96S+7I89 (8 additional encoders)
- zmrdko
14 Feb 2023 08:29 - 14 Feb 2023 08:29 #264489
by zmrdko
Thanks for quick answer.
I would like to use it with 4 delta servo drives (one dual axis).
I'm just not sure, if its better to use step/dir with closed loop in servo drive, or analog + encoder with closed loop in linuxcnc. (if I understand it correctly).
What would you suggest?
Thank you very much
Thank you very much
Last edit: 14 Feb 2023 08:29 by zmrdko.
- Thank you received: 7491
14 Feb 2023 12:25 #264503
Replied by tommylight on topic 7i95 availability
LinuxCNC cam also do step/dir with encoder feedback, so the loop can be closed in drives and LinuxCNC.
If you got them as a set, they usually come set up, so it is easier to use step/dir withot feedback.
You can add feedback later, after you get more comfortable with LinuxCNC.
15 Feb 2023 02:53 - 15 Feb 2023 02:54 #264547
7I95T protos were perfect so we will have a small quantity for sale in a couple of days.
Last edit: 15 Feb 2023 02:54 by PCW.
16 Feb 2023 16:21 #264631
A few 7I95Ts in the store now. Production qtys will be available in about 2 months
- suspension
30 Jun 2023 18:57 #274532
by suspension
Replied by suspension on topic 7i95 availability
I guess these are also out of stock now. Any idea when would this or 7I95 be available again?
-Sus
-Sus
30 Jun 2023 19:23 #274534
We should have 7I95Ts in about 2 weeks
- Unlogic
- Thank you received: 128
04 Jul 2023 01:27 - 04 Jul 2023 01:28 #274723
by Unlogic
Replied by Unlogic on topic 7i95 availability
Is it possible to preorder a 7I95T board?
Last edit: 04 Jul 2023 01:28 by Unlogic.
Time to create page: 0.098 seconds
