Firmware File for 7i76e + 7i78
- scda
- Thank you received: 3
19 Feb 2023 11:28 #264802
by scda
Firmware File for 7i76e + 7i78 was created by scda
Hello all,
I am running a 7i76e in a cnc milling machine with an atc. To add a sinkEDM feature to the machine I want to use the adaptive feed function and a "virtual encoder" (Stm32 generated sqare wave signal) for controlling the forward and reverse of the GCode.
For this I decided to add a second encoder input. There are no free inputs left on the 7i76e. So I went with the 7i78.
What kind of firmware does the 7i76e require to run with the 7i78? I can see that there is a 7i76e_7i78x1PD.bit but also a 7i76e_7i76x1_7i78x1D.bit file. Which one should I use? I tried the first firmware but the card was not recognized. Do I have to change anything in the .hal file (since it it as passive extension card)?
When I used the 7i76e_7i76x1_7i78x1D.bit firmware, my spindle encoder on the 7i76e did not work anymore....
Thanks for any tipps or hints.
- Thank you received: 5330
19 Feb 2023 15:40 #264809
Replied by PCW on topic Firmware File for 7i76e + 7i78
The 7I78 card is passive so "7I78" will not show up anywhere in hal
the new encoder on the 7i78 will be hm2_7i76e.0,encoder.01.xxxxx
- scda
19 Feb 2023 15:45 #264812
by scda
Replied by scda on topic Firmware File for 7i76e + 7i78
Hi
Thanks for the help.
Just modified my HAL file accordingly.
This fixed it
Had to change "num_encoders =" to 2 and now the encoder is recognized.
Cheers,
D
This fixed it
Cheers,
D
- shogan50
10 Mar 2023 22:13 #266343
by shogan50
Replied by shogan50 on topic Firmware File for 7i76e + 7i78
I'm trying to set up the same thing for a 6th stepgen. Would you mind sharing your .hal file. When I set num_stepgens=6, it says only 5 available.
10 Mar 2023 23:17 #266348
Did you update the 7I76E firmware with 7i76e_7i76x1_7i78x1D.bit?
- shogan50
10 Mar 2023 23:30 #266351
by shogan50
No. Trying to figure out how to do that with 7i76e_7i78x1PD.bit. AFAICT there is mesaflash or you can specify the firmware to load in the hal file. The former isn't available on my (mint) installation and not available on apt-get, so I assume obsolete. Trying to figure out where to place the file so the loadrt hm2_eth config can find it.
11 Mar 2023 00:59 - 11 Mar 2023 00:59 #266363
You must update the 7I76E flash memory with mesaflash.
Only on very old cards (5I20, 7I43 etc) can you specify the
firmware on the driver command line.
mesaflash --device 7i76e --addr [card_IP_address] --write 7i76e_7i76x1_7i78x1D.bit
Last edit: 11 Mar 2023 00:59 by PCW.
- scda
11 Mar 2023 08:46 #266389
by scda
If you flash the correct firmware with mesaflash (make sure you use the latest mesaflash tool) you can just add it in the hal file as you have written in the post above. I changed my hal file: num_encoders=1 to num_encoders=2. That is it (if you use the right firmware on the card).
There is a nice overview for the mesaflash tool. www.mankier.com/1/mesaflash
- shogan50
19 Mar 2023 01:52 #267049
by shogan50
Thanks for your help. I had something weird going on were apt couldn't find mesaflash on my linux mint machine. I built from git and it worked. Subsequently I decided to do a fresh install of the iso and mesaflash is no available on apt.
