Where to learn to build or modify custom bit files for my Mesa cards?
21 Feb 2023 15:15 #264960 by DrKnow65
I am looking to find information on how to modify / build / compile custom bit files for some of the Mesa boards I am using with my builds.
I have 7i90hd's on parallel ports, 7i90hd on a raspberry pi, 7i92tm's, and 7i98's. I have a hand full of daughter boards, 7i85s, 7i88, 7i67d, 7i77, etc.
For example if I wanted to build a bespoke daughter board to condition signals for stuff like IO with a couple PWM DAC outputs using the empty P3 port on a 7i98+7i85+7i77, and was going to experiment and iterate frequently, where would I learn to manipulate the bit files?
I will also be doing some connecting of inexpensive breakout boards (17-IO) to the 50pin headers (24-IO) on the 7i90hd's which would the have (7) unused IO pins that I could make use of in various ways.
Specifically I am looking to remove burden from the helpful folks here on the forum (mostly PCW) as I fumble and bumble my way through learning the EE side of customizing my own daughter board hardware.
Google is showing me no love :( where do I go looking?
Jeff
21 Feb 2023 16:13 #264964 by PCW
The following user(s) said Thank You: DrKnow65
28 Feb 2023 17:36 #265581 by DrKnow65
ERROR:HDLCompiler:104 - "/home/jeffs/linuxcnc/configs/7i90/configs/hostmot2/source/hostmot2/inm.vhd" Line 71: Cannot find <ibound> in library <work>. Please ensure that the library was compiled, and that a library and a use clause are present in the VHDL file.
Parsing entity <inm>.
ERROR:HDLCompiler:854 - "/home/jeffs/linuxcnc/configs/7i90/configs/hostmot2/source/hostmot2/inm.vhd" Line 73: Unit <inm> ignored due to previous errors.
Parsing architecture <behavioral> of entity <inm>.
ERROR:HDLCompiler:374 - "/home/jeffs/linuxcnc/configs/7i90/configs/hostmot2/source/hostmot2/inm.vhd" Line 94: Entity <inm> is not yet compiled.
ERROR:HDLCompiler:69 - "/home/jeffs/linuxcnc/configs/7i90/configs/hostmot2/source/hostmot2/inm.vhd" Line 95: <std_logic_vector> is not declared.
ERROR:HDLCompiler:69 - "/home/jeffs/linuxcnc/configs/7i90/configs/hostmot2/source/hostmot2/inm.vhd" Line 96: <std_logic_vector> is not declared.
ERROR:HDLCompiler:69 - "/home/jeffs/linuxcnc/configs/7i90/configs/hostmot2/source/hostmot2/inm.vhd" Line 97: <std_logic> is not declared.
ERROR:HDLCompiler:69 - "/home/jeffs/linuxcnc/configs/7i90/configs/hostmot2/source/hostmot2/inm.vhd" Line 98: <std_logic_vector> is not declared.
ERROR:HDLCompiler:69 - "/home/jeffs/linuxcnc/configs/7i90/configs/hostmot2/source/hostmot2/inm.vhd" Line 99: <std_logic_vector> is not declared.
ERROR:HDLCompiler:69 - "/home/jeffs/linuxcnc/configs/7i90/configs/hostmot2/source/hostmot2/inm.vhd" Line 100: <std_logic_vector> is not declared.
ERROR:HDLCompiler:69 - "/home/jeffs/linuxcnc/configs/7i90/configs/hostmot2/source/hostmot2/inm.vhd" Line 101: <std_logic_vector> is not declared.
ERROR:HDLCompiler:69 - "/home/jeffs/linuxcnc/configs/7i90/configs/hostmot2/source/hostmot2/inm.vhd" Line 102: <std_logic_vector> is not declared.
ERROR:HDLCompiler:69 - "/home/jeffs/linuxcnc/configs/7i90/configs/hostmot2/source/hostmot2/inm.vhd" Line 103: <std_logic_vector> is not declared.
ERROR:HDLCompiler:69 - "/home/jeffs/linuxcnc/configs/7i90/configs/hostmot2/source/hostmot2/inm.vhd" Line 104: <std_logic_vector> is not declared.
ERROR:HDLCompiler:69 - "/home/jeffs/linuxcnc/configs/7i90/configs/hostmot2/source/hostmot2/inm.vhd" Line 105: <inwidth> is not declared.
ERROR:HDLCompiler:69 - "/home/jeffs/linuxcnc/configs/7i90/configs/hostmot2/source/hostmot2/inm.vhd" Line 107: <std_logic> is not declared.
ERROR:HDLCompiler:69 - "/home/jeffs/linuxcnc/configs/7i90/configs/hostmot2/source/hostmot2/inm.vhd" Line 108: <std_logic_vector> is not declared.
ERROR:HDLCompiler:69 - "/home/jeffs/linuxcnc/configs/7i90/configs/hostmot2/source/hostmot2/inm.vhd" Line 109: <std_logic> is not declared.
ERROR:HDLCompiler:69 - "/home/jeffs/linuxcnc/configs/7i90/configs/hostmot2/source/hostmot2/inm.vhd" Line 110: <std_logic_vector> is not declared.
ERROR:HDLCompiler:69 - "/home/jeffs/linuxcnc/configs/7i90/configs/hostmot2/source/hostmot2/inm.vhd" Line 111: <std_logic_vector> is not declared.
Sorry, too many errors..
Looks like I am either missing a dependancy somewhere, or there was a problem "merging" the file into ISE 14.7?
Any advise where I might begin the search?
28 Feb 2023 18:04 #265582 by DrKnow65
I did " sudo apt install ghdl " without it changing anything, just for information.
28 Feb 2023 18:16 #265583 by PCW
The various project files may not be up-to-date
to fix, add the missing file to the project (ibound.vhd in this case)
(in the GUI right click in the file area and select add file)
28 Feb 2023 18:19 #265585 by DrKnow65
"A known limitation of the new parser"
Not sure what exactly the procedures are for finding and adding the files and compiling the library again....
28 Feb 2023 18:26 #265586 by DrKnow65
You nailed it, I didn't expect the inbound.vhd and oneshot.vhd to be in the dropdown to add as sources.
Thank you again.
I am now down to one error,
Map:258 - A problem was encountered attempting to get the license for this
architecture.
I suppose something here is proprietary and needs a signature maybe?
28 Feb 2023 18:34 #265590 by PCW
Did you register your copy of webpack?
28 Feb 2023 18:39 #265593 by DrKnow65
I did, but I also had to change an nvme that went sideways and it changed my MAC or something.
I found that my "Host ID Matches" was red for the ISE in the license manager though everything else was green.
Getting the license sorted now.
You are good at this :) I'm working on getting better too.
28 Feb 2023 19:20 #265599 by DrKnow65
"Network Interface Card (NIC) ID: 000000000000" on the license manager I suspect is where I am getting shut down.
I have the correct (licensed) mac showing up when I "ip link show" in the terminal, it just isn't populating in the license manager.
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN mode DEFAULT group default qlen 1000
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
2: enp0s31f6: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP mode DEFAULT group default qlen 1000
    link/ether nn:nn:nn:nn:nn:nn brd ff:ff:ff:ff:ff:ff
(the "nn:nn:nn:nn:nn:nn: is my redacted mac)
I wonder if the license manager is somehow populating with the link/loopback ID?
I think a good Linux user is a good troubleshooter. I'm trying to persevere...
Moderators: PCW, jmelson
Time to create page: 1.410 seconds
