Mesa 7i96s handwheel no motion
  • greekart
  • greekart's Avatar Topic Author
  • Junior Member
  • Junior Member
23 Feb 2023 04:10 - 23 Feb 2023 04:11 #265099 by greekart
Replied by greekart on topic Mesa 7i96s handwheel no motion
ok so now you know it's something to do with the MPG.
Could be connected to wrong physical pins for the encoder number you want.
Again you can use halmeter to check all the Mesa encoder counter pins (hm2_7i96s.0.inm.00.enc0-count etc) to see if any count up and down with the MPG.
Could be physically wired wrong or something wrong with the MPG it's self.
As it look to me is working, all Mesa encoder counter pins and what they do is below.
Warning: Spoiler!
Last edit: 23 Feb 2023 04:11 by greekart.
23 Feb 2023 04:13 #265100 by cmorley
Replied by cmorley on topic Mesa 7i96s handwheel no motion
Is there no pin named as such or similar?
  • greekart
  • Junior Member
  • Junior Member
23 Feb 2023 04:16 - 23 Feb 2023 04:17 #265101 by greekart
Nothing like that, Gmoccapy loads and working.
Last edit: 23 Feb 2023 04:17 by greekart.
23 Feb 2023 04:17 #265102 by cmorley
Sorry, are you saying hm2_7i96s.0.encoder.00.count does change with the MPG movement
  • greekart
  • Junior Member
  • Junior Member
23 Feb 2023 04:19 - 23 Feb 2023 04:19 #265103 by greekart
Yes, i see changes at pin, no movement and no Gmoccapy DRO change.
Last edit: 23 Feb 2023 04:19 by greekart.
23 Feb 2023 04:25 #265104 by cmorley
in your custom.hal file you have this line:
net encoder-counts <= hm2_7i96s.0.inm.00.enc0-count
which is not the right encoder pin.
It seems this would be the right pin:
net encoder-counts <= hm2_7i96s.0.encoder.00.count
Not sure why it didn't error though.
The following user(s) said Thank You: greekart
  • greekart
  • Junior Member
  • Junior Member
23 Feb 2023 04:32 #265105 by greekart
I can't express how much i thank you!!
It works with only the change you mention.
23 Feb 2023 04:36 #265106 by cmorley
Glad I could help.
  • Moderator
  • Moderator
23 Feb 2023 13:07 #265116 by tommylight
Replied by tommylight on topic Mesa 7i96s handwheel no motion
Should we move this topic back to "driver board", leave it here or move it somewhere else?
Thank you.
24 Feb 2023 19:27 #265268 by HansU
Replied by HansU on topic Mesa 7i96s handwheel no motion
Yeah would fit better in a driver sub-forum.
Moderators: PCW, jmelson
Time to create page: 0.109 seconds
