Optiplex 755
  • zz912
  • zz912's Avatar Topic Author
  • Platinum Member
  • Platinum Member
03 Mar 2023 23:30 #265811 by zz912
Optiplex 755 was created by zz912
Hello,
I have interesting problem. I have old computer. Everything is OK. Latency test is around 50 000. This is nice. But sometimes I get message about bad latency. So I made tests in MesaCT configurator:
The test went wrong. I do not want increase Servo Thread Period.
Is my computer weak for Mesa? Can something be done about it? Or should I just order a more powerful PC.
I tried using only the basic configuration from PNCconf and using LCNC 2.8.0. The values improved, but only slightly.
04 Mar 2023 01:05 #265813 by PCW
Replied by PCW on topic Optiplex 755
Did you disable AMT in the BIOS?
Disable IRQ coalescing?
  • zz912
  • Platinum Member
  • Platinum Member
07 Mar 2023 15:52 - 07 Mar 2023 16:11 #266029 by zz912
Replied by zz912 on topic Optiplex 755
I think, coalescing is off:
[code]jarda@CNC1:~$ sudo ethtool -c enp0s25
Coalesce parameters for enp0s25:
Adaptive RX: off  TX: off
stats-block-usecs: 0
sample-interval: 0
pkt-rate-low: 0
pkt-rate-high: 0
rx-usecs: 0
rx-frames: 0
rx-usecs-irq: 0
rx-frames-irq: 0
tx-usecs: 0
tx-frames: 0
tx-usecs-irq: 0
tx-frames-irq: 0
rx-usecs-low: 0
rx-frame-low: 0
tx-usecs-low: 0
tx-frame-low: 0
rx-usecs-high: 0
rx-frame-high: 0
tx-usecs-high: 0
tx-frame-high: 0
jarda@CNC1:~$
[/code]
Bios has not got anything like AMT.
Last edit: 07 Mar 2023 16:11 by zz912.
07 Mar 2023 16:23 #266036 by PCW
Its in ME setup (needs a password) I think AMT is enabled by default on the 755
  • zz912
  • Platinum Member
  • Platinum Member
07 Mar 2023 16:42 - 07 Mar 2023 17:01 #266040 by zz912
Is ME setup in BIOS?
Edit: ME is MEBx
Last edit: 07 Mar 2023 17:01 by zz912.
07 Mar 2023 17:04 #266042 by PCW
Yes, you probably have to enable the MEBx message to access is through the BIOS setup
(and hope that the BIOS gives you access to AMT setup)
  • zz912
  • Platinum Member
  • Platinum Member
07 Mar 2023 17:36 #266047 by zz912
I disabled it, but it did not help.
07 Mar 2023 18:03 #266049 by PCW
Well its necessary but maybe not all that's needed
What kernel are you using?
(its known the the default Debian RT kernels are not very good)
  • zz912
  • Platinum Member
  • Platinum Member
07 Mar 2023 18:30 #266052 by zz912
Hello,
1) Kernel is in Pictures
2) I have new knowledge. We can rule out a Mesa card error. A latency-test is enough to simulate the problem. Look at the following picture:
As soon as I start the latency test, the message immediately starts:
Unexpected realtime delay on task 0 with period 25000
This Message will only display once per session.
Run the Latency Test and resolve before continuing.
In this image, I managed to simulate that the error message only appeared after a while. Nevertheless, the latency-test showed satisfactory values. Why?
3) I tested branche 2.8.0 and 2.9. Both is same.
07 Mar 2023 18:56 #266053 by PCW
A latency error may be expected with a 40 KHz
base thread but Its not too meaningful though because:
1. A base thread is not needed with Mesa hardware
2. The important thing is Ethernet latency which the latency test doesn't measure
You can get an idea of Ethernet latency with:
sudo chrt 99 ping -i .001 -q 10.10.10.10
(let run for a few minutes and then control-C)
Moderators: PCW, jmelson
Time to create page: 0.321 seconds
