7i96
26 Mar 2023 15:23 #267531 by Powerhouse.
7i96 was created by Powerhouse.
HOW DO I FLASH A 7I96 ?
HOW DO I KNOW THE CARD WORKS ?
IS THERE ONE PERSON ON THIS FORUM THAT IS USING A PI4 AND MESA 7I96?
26 Mar 2023 22:00 #267563 by rmu
Replied by rmu on topic 7i96
First you need to fix your keyboard.
Second, tell where you are stuck, and what your proficiency is with linux. Nobody can know that. So to check connectivity, use ping. To flash, use mesaflash. Generate configuration with pncconf. This english linuxcnc.org/docs/2.9/html/config/pncconf.html seems to be normal enough for me.
26 Mar 2023 22:24 - 26 Mar 2023 22:25 #267568 by JT
Replied by JT on topic 7i96
What rmu means is caps lock is like shouting!
Why would you want to flash a 7i96?
My Mesa Configuration tool can flash mesa cards and a whole lot more...
gnipsel.com/linuxcnc/mesact/index.html
If you have set up the correct IP address on the 7i96 and the Rpi you can use ping to test or you can use my tool to check that the communications to the board is correct.
JT
Last edit: 26 Mar 2023 22:25 by JT.
Moderators: PCW, jmelson
Time to create page: 0.228 seconds
