Mesaflash --dbname# <name>
- JT
- Thank you received: 595
30 Mar 2023 13:02 #267908
by JT
Mesaflash --dbname# <name> was created by JT
I have a 7i92t with a 7i76 on P2 and when I issue the following I get:
and if I change dbname to 2 I get
I'm not sure what I'm looking at and does the daughter board need to be connected to use dbname?
JT
john@cave:~$ mesaflash --device 7i92t --addr 10.10.10.10 --readhmid --dbname1 7i76
Configuration Name: HOSTMOT2
BoardName : MESA7I92
FPGA Size: 20 KGates
FPGA Pins: 256
Number of IO Ports: 2
Width of one I/O port: 17
Clock Low frequency: 100.0000 MHz
Clock High frequency: 180.0000 MHz
IDROM Type: 3
Instance Stride 0: 4
Instance Stride 1: 64
Register Stride 0: 256
Register Stride 1: 256
Modules in configuration:
Module: DPLL
There are 1 of DPLL in configuration
Version: 0
Registers: 7
BaseAddress: 7000
ClockFrequency: 100.000 MHz
Register Stride: 256 bytes
Instance Stride: 4 bytes
Module: WatchDog
There are 1 of WatchDog in configuration
Version: 0
Registers: 3
BaseAddress: 0C00
Module: IOPort
There are 2 of IOPort in configuration
Version: 0
Registers: 5
BaseAddress: 1000
Module: QCount
There are 2 of QCount in configuration
Version: 2
Registers: 5
BaseAddress: 3000
Module: SSerial
There are 1 of SSerial in configuration
Version: 0
Registers: 6
BaseAddress: 5B00
Instance Stride: 64 bytes
Module: StepGen
There are 10 of StepGen in configuration
Version: 2
Registers: 10
BaseAddress: 2000
Module: LED
There are 1 of LED in configuration
Version: 0
Registers: 1
BaseAddress: 0200
Configuration pin-out:
IO Connections for P2 -> 7I76
Pin# I/O Pri. func Sec. func Chan Sec. Pin func Sec. Pin Dir
TB2-4,5 0 IOPort StepGen 0 Dir/Table2 (Out)
TB2-2,3 1 IOPort StepGen 0 Step/Table1 (Out)
TB2-10,11 2 IOPort StepGen 1 Dir/Table2 (Out)
TB2-8,9 3 IOPort StepGen 1 Step/Table1 (Out)
TB2-16,17 4 IOPort StepGen 2 Dir/Table2 (Out)
TB2-14,15 5 IOPort StepGen 2 Step/Table1 (Out)
TB2-22,23 6 IOPort StepGen 3 Dir/Table2 (Out)
TB2-20,21 7 IOPort StepGen 3 Step/Table1 (Out)
TB3-4,5 8 IOPort StepGen 4 Dir/Table2 (Out)
TB3-2,3 9 IOPort StepGen 4 Step/Table1 (Out)
Internal-Field-IO 10 IOPort SSerial 0 TXData0 (Out)
Internal-Field-IO 11 IOPort SSerial 0 RXData0 (In)
TB3-18,19 12 IOPort SSerial 0 TXData1 (Out)
TB3-16,17 13 IOPort SSerial 0 RXData1 (In)
TB3-13,14 14 IOPort QCount 0 Quad-IDX (In)
TB3-10,11 15 IOPort QCount 0 Quad-B (In)
TB3-7,8 16 IOPort QCount 0 Quad-A (In)
IO Connections for P1
DB25 pin# I/O Pri. func Sec. func Chan Sec. Pin func Sec. Pin Dir
1 17 IOPort StepGen 5 Dir/Table2 (Out)
14 18 IOPort StepGen 5 Step/Table1 (Out)
2 19 IOPort StepGen 6 Dir/Table2 (Out)
15 20 IOPort StepGen 6 Step/Table1 (Out)
3 21 IOPort StepGen 7 Dir/Table2 (Out)
16 22 IOPort StepGen 7 Step/Table1 (Out)
4 23 IOPort StepGen 8 Dir/Table2 (Out)
17 24 IOPort StepGen 8 Step/Table1 (Out)
5 25 IOPort StepGen 9 Dir/Table2 (Out)
6 26 IOPort StepGen 9 Step/Table1 (Out)
7 27 IOPort SSerial 0 TXData2 (Out)
8 28 IOPort SSerial 0 RXData2 (In)
9 29 IOPort SSerial 0 TXData3 (Out)
10 30 IOPort SSerial 0 RXData3 (In)
11 31 IOPort QCount 1 Quad-IDX (In)
12 32 IOPort QCount 1 Quad-B (In)
13 33 IOPort QCount 1 Quad-A (In)and if I change dbname to 2 I get
john@cave:~$ mesaflash --device 7i92t --addr 10.10.10.10 --readhmid --dbname2 7i76
FPGA Pins: 256
IDROM Type: 3
Module: DPLL
Version: 0
Registers: 7
BaseAddress: 7000
Module: WatchDog
Version: 0
Registers: 3
BaseAddress: 0C00
Module: IOPort
Version: 0
Registers: 5
BaseAddress: 1000
Module: QCount
Version: 2
Registers: 5
BaseAddress: 3000
Module: SSerial
Version: 0
Registers: 6
BaseAddress: 5B00
Module: StepGen
Version: 2
Registers: 10
BaseAddress: 2000
Module: LED
Version: 0
Registers: 1
BaseAddress: 0200
1 0 IOPort StepGen 0 Dir/Table2 (Out)
14 1 IOPort StepGen 0 Step/Table1 (Out)
2 2 IOPort StepGen 1 Dir/Table2 (Out)
15 3 IOPort StepGen 1 Step/Table1 (Out)
3 4 IOPort StepGen 2 Dir/Table2 (Out)
16 5 IOPort StepGen 2 Step/Table1 (Out)
4 6 IOPort StepGen 3 Dir/Table2 (Out)
17 7 IOPort StepGen 3 Step/Table1 (Out)
6 9 IOPort StepGen 4 Step/Table1 (Out)
7 10 IOPort SSerial 0 TXData0 (Out)
8 11 IOPort SSerial 0 RXData0 (In)
10 13 IOPort SSerial 0 RXData1 (In)
11 14 IOPort QCount 0 Quad-IDX (In)
12 15 IOPort QCount 0 Quad-B (In)
13 16 IOPort QCount 0 Quad-A (In)
IO Connections for P1 -> 7I76
TB2-4,5 17 IOPort StepGen 5 Dir/Table2 (Out)
TB2-2,3 18 IOPort StepGen 5 Step/Table1 (Out)
TB2-10,11 19 IOPort StepGen 6 Dir/Table2 (Out)
TB2-8,9 20 IOPort StepGen 6 Step/Table1 (Out)
TB2-16,17 21 IOPort StepGen 7 Dir/Table2 (Out)
TB2-14,15 22 IOPort StepGen 7 Step/Table1 (Out)
TB2-22,23 23 IOPort StepGen 8 Dir/Table2 (Out)
TB2-20,21 24 IOPort StepGen 8 Step/Table1 (Out)
TB3-4,5 25 IOPort StepGen 9 Dir/Table2 (Out)
TB3-2,3 26 IOPort StepGen 9 Step/Table1 (Out)
Internal-Field-IO 27 IOPort SSerial 0 TXData2 (Out)
Internal-Field-IO 28 IOPort SSerial 0 RXData2 (In)
TB3-18,19 29 IOPort SSerial 0 TXData3 (Out)
TB3-16,17 30 IOPort SSerial 0 RXData3 (In)
TB3-13,14 31 IOPort QCount 1 Quad-IDX (In)
TB3-10,11 32 IOPort QCount 1 Quad-B (In)
TB3-7,8 33 IOPort QCount 1 Quad-A (In)I'm not sure what I'm looking at and does the daughter board need to be connected to use dbname?
JT
- JT
30 Mar 2023 13:05 #267909
by JT
Replied by JT on topic Mesaflash --dbname# <name>
Also from the man page
What is considered the first FPGA connector?
JT
--dbname# <name> Set daughter board name to <name> for FPGA connector <N>
Allows readhmid to include daughterboard terminal names,
where # can be in the range 1 to 6
(1 means first FPGA connector).What is considered the first FPGA connector?
JT
- Thank you received: 5334
30 Mar 2023 15:11 #267915
Replied by PCW on topic Mesaflash --dbname# <name>
The dbname connector order is in order of GPIO so dbname1 is the connector with GPIO 0..N
