Choosing correct daughtercard for 7I96S
06 Apr 2023 09:53 - 06 Apr 2023 12:53 #268398 by stavy
My CNC will run six motors, xyyzbc.
7I96S can run up to 5 motors so I need a daughtercard, I'm thinking about 7I78.
Are they compatible with LinuxCNC when used together?
Can the DB25M-IDC26 connector be used to connect between those two?
Perhaps a different combination would be better, such as the 7i76e? I don't need two daughter cards.
store.mesanet.com/index.php?route=produc...oduct&product_id=374
store.mesanet.com/index.php?route=produc...oduct&product_id=121
store.mesanet.com/index.php?route=produc...oduct&product_id=315
Last edit: 06 Apr 2023 12:53 by stavy.
  • Moderator
  • Moderator
06 Apr 2023 10:28 #268408 by tommylight
Replied by tommylight on topic Choosing correct daughtercard for 7I96S
You can also use a cheap BOB.
Or wire the drive directly to IDC26 header on the 7i96S, but care must be taken as those are sensitive pins.
And prefferably, use shielded cable.
The following user(s) said Thank You: stavy
06 Apr 2023 10:48 #268409 by stavy
Replied by stavy on topic Choosing correct daughtercard for 7I96S
I'm not an expert, so I prefer to pay a high price for correct and high-quality parts.
Is the combination I mentioned above possible, or is something else recommended?
  • Moderator
  • Moderator
06 Apr 2023 12:47 #268421 by tommylight
Sorry, never used a 7i78 and on the phone...
7i76 should work but it is an overkill as it has 5 step/dir, spindle with encoder, 32 in and 16 out, etc.
Moderators: PCW, jmelson
Time to create page: 0.076 seconds
