Mesa 7C80 Spindel out Direction and Enable
10 Apr 2023 18:06 #268768 by maxguapo
Hi, In the last weeks I managed thanks to the may examples I found in the forum to configure the above bord with a MPG pendant, the steppers, an encoder and the spindle speed for a lathe. I struggle now with the output of the spindle interface (connector TB5 on the board) that the board provides for "direction" and "enable".
In the HAL file I have the following line:
net spindle-enable             <=  spindle.0.on
net spindle-cw                 <=  spindle.0.forward
net spindle-ccw                <=  spindle.0.reverse
and then
net spindle cw => hm2_7c80.0.gpio.020.out
net spindle-enabel => hm2_7c80.0.gpio.021.out
In the hal-meter the hm2_7c80.0.gpio.020.out or hm2_7c80.0.gpio.021.out pin changes state from true to false and vvs when I push to appropriate buttons on the Axis interface, but I do not get a reaction at the physical output. At the physical pin a ordinary relays is connected. When I send the signal to a ssr output all works. But I think that was not intended from Mesa. Do I have the right pins or what is my mistake?
From Mesa I got a funny bunny, but the bunny did not solve my problems until now. May be he (the bunny) was to much occupied because of the Easter holydays ;-( . Anyway......
Any help would be highly appreciated!
Regards, maxguapo
10 Apr 2023 18:18 #268770 by PCW
Have you set GPIO20 and GPIO21 to output mode?
10 Apr 2023 18:32 #268772 by maxguapo
Replied by maxguapo on topic Mesa 7C80 Spindel out Direction and Enable
Hi PCW, thank you for the quick reply.
No, I did not set the outputs to out. I found pins .020.in and 020.in-invert (?) and 020.out and thought that this would be enough.
Where do I have to set the pins for output?
Regards, maxguapo
10 Apr 2023 19:13 #268778 by PCW
You would need to set the "is_output" parameters for GPIO20 and GPIO21
(all HostMot2 GPIO starts out in input mode and must be specifically
set to output mode to use as an output)
11 Apr 2023 18:01 #268835 by maxguapo
Good evening PCW, thank you for your help. Now all works as expected.
Have a good time!
Regards, maxguapo
Moderators: PCW, jmelson
Time to create page: 0.300 seconds
