- Thank you received: 3
If the ENA output is always on it may be the you have the polarity backwards.Do you know what the exact wiring issue was? I am having this same problem and have tried endless combinations. I’m using a Altivar32 drive, but it’s as if the enable and direction switches on the 7i76e never switch off… I have to physically disconnect direction pin to get the drive to reactivate… Thanks!
