problem with setup of ah 7i92 with 7i77, 7i71, 7,70 and 7i74 with missing smarts
24 Apr 2023 19:58 #269775 by MarkusBec
Hello
I have a problem with my stetup.
i have flashed the 7i92 bit the bitfile 7i92_7i77_7i74D.bit
at the moment i am waiting for the 7i74 to connect a stmbl and the 7i70
to the 7i77 i connected the 7i71 but it is not recognised.
this is what i get with mesa flash:
IO Connections for P2
Pin#  I/O   Pri. func    Sec. func       Chan      Pin func        Pin Dir
 1      0   IOPort       SSerial          0        TXEn2           (Out)
14      1   IOPort       SSerial          0        TXData2         (Out)
 2      2   IOPort       SSerial          0        RXData2         (In)
15      3   IOPort       SSerial          0        TXData1         (Out)
 3      4   IOPort       SSerial          0        RXData1         (In)
16      5   IOPort       SSerial          0        TXData0         (Out)
 4      6   IOPort       SSerial          0        RXData0         (In)
17      7   IOPort       MuxedQCountSel   0        MuxSel0         (Out)
 5      8   IOPort       MuxedQCount      0        MuxQ-A          (In)
 6      9   IOPort       MuxedQCount      0        MuxQ-B          (In)
 7     10   IOPort       MuxedQCount      0        MuxQ-IDX        (In)
 8     11   IOPort       MuxedQCount      1        MuxQ-A          (In)
 9     12   IOPort       MuxedQCount      1        MuxQ-B          (In)
10     13   IOPort       MuxedQCount      1        MuxQ-IDX        (In)
11     14   IOPort       MuxedQCount      2        MuxQ-A          (In)
12     15   IOPort       MuxedQCount      2        MuxQ-B          (In)
13     16   IOPort       MuxedQCount      2        MuxQ-IDX        (In)
IO Connections for P1
 1     17   IOPort       SSerial          1        RXData0         (In)
14     18   IOPort       SSerial          1        RXData1         (In)
 2     19   IOPort       SSerial          1        RXData2         (In)
15     20   IOPort       SSerial          1        RXData3         (In)
 3     21   IOPort       SSerial          1        TXData0         (Out)
16     22   IOPort       SSerial          1        TXData1         (Out)
 4     23   IOPort       SSerial          1        TXData2         (Out)
17     24   IOPort       SSerial          1        TXData3         (Out)
 5     25   IOPort       SSerial          1        RXData4         (In)
 6     26   IOPort       SSerial          1        RXData5         (In)
 7     27   IOPort       None
 8     28   IOPort       None
 9     29   IOPort       SSerial          1        TXData4         (Out)
10     30   IOPort       SSerial          1        TXData5         (Out)
11     31   IOPort       None
12     32   IOPort       None
13     33   IOPort       None
and this is my linuxcnc error:
hm2_eth: loading Mesa AnyIO HostMot2 ethernet driver version 0.2
hm2_eth: 10.10.10.10: INFO: Hardware address (MAC): 00:60:1b:12:02:08
hm2_eth: discovered 7I92
hm2/hm2_7i92.0: Low Level init 0.15
hm2/hm2_7i92.0: Smart Serial Firmware Version 43
Board hm2_7i92.0.7i77.0.0 Hardware Mode 0 = standard
Board hm2_7i92.0.7i77.0.0 Software Mode 0 = input_output
Board hm2_7i92.0.7i77.0.0 Software Mode 1 = io_analog
Board hm2_7i92.0.7i77.0.0 Software Mode 2 = io_analog_fieldvoltage
Board hm2_7i92.0.7i77.0.0 Software Mode 3 = io_encoder_analog_fieldvoltage
Board hm2_7i92.0.7i77.0.1 Hardware Mode 0 = standard
Board hm2_7i92.0.7i77.0.1 Software Mode 0 = analogout_enables
hm2/hm2_7i92.0: 34 I/O Pins used:
hm2/hm2_7i92.0:     IO Pin 000 (P2-01): IOPort
hm2/hm2_7i92.0:     IO Pin 001 (P2-14): IOPort
hm2/hm2_7i92.0:     IO Pin 002 (P2-02): IOPort
hm2/hm2_7i92.0:     IO Pin 003 (P2-15): Smart Serial Interface #0, pin tx1 (Output)
hm2/hm2_7i92.0:     IO Pin 004 (P2-03): Smart Serial Interface #0, pin rx1 (Input)
hm2/hm2_7i92.0:     IO Pin 005 (P2-16): Smart Serial Interface #0, pin tx0 (Output)
hm2/hm2_7i92.0:     IO Pin 006 (P2-04): Smart Serial Interface #0, pin rx0 (Input)
hm2/hm2_7i92.0:     IO Pin 007 (P2-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
hm2/hm2_7i92.0:     IO Pin 008 (P2-05): Muxed Encoder #0, pin Muxed A (Input)
hm2/hm2_7i92.0:     IO Pin 009 (P2-06): Muxed Encoder #0, pin Muxed B (Input)
hm2/hm2_7i92.0:     IO Pin 010 (P2-07): Muxed Encoder #0, pin Muxed Index (Input)
hm2/hm2_7i92.0:     IO Pin 011 (P2-08): Muxed Encoder #1, pin Muxed A (Input)
hm2/hm2_7i92.0:     IO Pin 012 (P2-09): Muxed Encoder #1, pin Muxed B (Input)
hm2/hm2_7i92.0:     IO Pin 013 (P2-10): Muxed Encoder #1, pin Muxed Index (Input)
hm2/hm2_7i92.0:     IO Pin 014 (P2-11): Muxed Encoder #2, pin Muxed A (Input)
hm2/hm2_7i92.0:     IO Pin 015 (P2-12): Muxed Encoder #2, pin Muxed B (Input)
hm2/hm2_7i92.0:     IO Pin 016 (P2-13): Muxed Encoder #2, pin Muxed Index (Input)
hm2/hm2_7i92.0:     IO Pin 017 (P1-01): IOPort
hm2/hm2_7i92.0:     IO Pin 018 (P1-14): IOPort
hm2/hm2_7i92.0:     IO Pin 019 (P1-02): IOPort
hm2/hm2_7i92.0:     IO Pin 020 (P1-15): IOPort
hm2/hm2_7i92.0:     IO Pin 021 (P1-03): IOPort
hm2/hm2_7i92.0:     IO Pin 022 (P1-16): IOPort
hm2/hm2_7i92.0:     IO Pin 023 (P1-04): IOPort
hm2/hm2_7i92.0:     IO Pin 024 (P1-17): IOPort
hm2/hm2_7i92.0:     IO Pin 025 (P1-05): IOPort
hm2/hm2_7i92.0:     IO Pin 026 (P1-06): IOPort
hm2/hm2_7i92.0:     IO Pin 027 (P1-07): IOPort
hm2/hm2_7i92.0:     IO Pin 028 (P1-08): IOPort
hm2/hm2_7i92.0:     IO Pin 029 (P1-09): IOPort
hm2/hm2_7i92.0:     IO Pin 030 (P1-10): IOPort
hm2/hm2_7i92.0:     IO Pin 031 (P1-11): IOPort
hm2/hm2_7i92.0:     IO Pin 032 (P1-12): IOPort
hm2/hm2_7i92.0:     IO Pin 033 (P1-13): IOPort
hm2/hm2_7i92.0: registered
hm2_eth: in hm2_eth_reset
hm2_eth: HostMot2 ethernet driver unloaded
hm2: unloading
attached my config
File Name: spinner2.zip
File Size:11 KB
24 Apr 2023 21:03 #269781 by PCW
Does the 7I71 have field power?
24 Apr 2023 21:06 #269782 by MarkusBec
yes
i think this means it is not enable but i am not sure
i think i have enabled all ports with sserial_port_0=000 sserial_port_1=00000
24 Apr 2023 21:08 #269784 by PCW
The startup pin list just shows that no sserial device was found
Possibly connector wiring?
24 Apr 2023 22:39 #269793 by MarkusBec
the 7i71 was in setup mode. now it works
the error massage is a little bit misleading
Moderators: PCW, jmelson
