pwmgen enable mode-offset
- telmoram
29 Apr 2023 18:51 #270220
by telmoram
pwmgen enable mode-offset was created by telmoram
Hello can someone help me, i am using 7i90 mesa card and pwm for control servo motor with:
setp hm2_7i90.0.pwmgen.00.output-type 1 #PWM pin0
setp hm2_7i90.0.pwmgen.00.offset-mode 1 # offset mode so 50%=0
When starting linuxcnc the duty cycle is automatically set to 50%, but I need it to zero when pressing e-stop, I have used pwm enable to false, but the value of the duty cycle is kept at 50%, is there any of put pwm output to zero when pressing e-stop?
Thanks.
Thanks.
- Thank you received: 5334
29 Apr 2023 19:03 #270221
Replied by PCW on topic pwmgen enable mode-offset
The offset mode assumes you want 0 analog out (so 50% duty cycle) when disabled
If you need 0 PWM in offset mode when disabled you could add a mux component
and feed it the commaned PWM value in one input, full scale negative in the other
and select the mux input with machine-on
Time to create page: 0.087 seconds
