7i92 and mx4660 PNCconf and mesact, not able to create config.
11 May 2023 19:16 #271171 by CWALV_Puzzle
I have a 7i92 and mx4660 for use with a new dual y axis and ATC machine. I am a long time linux and linuxcnc user, this is my first mesa card.  Normally I get a config most of the way with the wizards and then edit the files by hand.  I have the 7i92 configured with the mx4660 .bin file using mesaflash.  So that's all good, but my googlefoo is failing me.
When I go to use PNCconf it does not have the mx4660 as an option and crashes when trying to read from the 7i92 in the advanced screen.  It also does not have xyyz as a beginning option.
Mesa Configuration Tool, mesact will not let me select a daughter board so it won't create a config.
What other options do I have?  Id rather not make a config from scratch or create one and have to change everything to get it to work.
Thank you.
11 May 2023 19:38 #271175 by JT
In MesaCT select the 7i92_5ABOBx2D.bit firmware and you can pick a stepper daughter card.
JT
Moderators: PCW, jmelson
