Connect a MKS Servo57c to a Mesa 7i96s
15 May 2023 18:19 #271412 by MartijnD
Connect a MKS Servo57c to a Mesa 7i96s was created by MartijnD
I am trying to connect a MKS Servo57c ( link ) to a Mesa 7i96s But for some reason I can not get it to run...
Here is the connection details of the Servo57c:
I tried these 2 variants:
In both cases the drive was enabled but not spinning while there where pulses on the DIR signal of the MESA card (could measure ~2 volts)
15 May 2023 18:23 - 15 May 2023 18:24 #271415 by PCW
Replied by PCW on topic Connect a MKS Servo57c to a Mesa 7i96s
DO NOT connect ANY 7I96S step/dir pin to GND or +5V
you are shorting out the driver chips and may cause damage
Last edit: 15 May 2023 18:24 by PCW.
15 May 2023 18:25 #271416 by snowgoer540
Replied by snowgoer540 on topic Connect a MKS Servo57c to a Mesa 7i96s
This is a double post.  Please dont do that.
Do you want me to delete the other thread or this one?
15 May 2023 18:29 - 15 May 2023 18:31 #271417 by MartijnD
Replied by MartijnD on topic Connect a MKS Servo57c to a Mesa 7i96s
I already asked to delete that before making a new post... so yes please
Last edit: 15 May 2023 18:31 by MartijnD.
15 May 2023 18:33 - 15 May 2023 18:35 #271418 by MartijnD
=calc(var(--scale-factor)*12.06px)From the manual, page 40:
STEP/DIR OUTPUTS
=calc(var(--scale-factor)*12.06px)STEP/DIR OUTPUT HIGH V=calc(var(--scale-factor)*12.06px) =calc(var(--scale-factor)*12.06px)4V=calc(var(--scale-factor)*12.06px) =calc(var(--scale-factor)*12.06px)----=calc(var(--scale-factor)*12.06px) =calc(var(--scale-factor)*12.06px)10 mA source
=calc(var(--scale-factor)*12.06px)STEP/DIR OUTPUT LOW V=calc(var(--scale-factor)*12.06px) =calc(var(--scale-factor)*12.06px)----=calc(var(--scale-factor)*12.06px) =calc(var(--scale-factor)*12.06px)1V=calc(var(--scale-factor)*12.06px) =calc(var(--scale-factor)*12.06px)10mA sink
=calc(var(--scale-factor)*12.06px)STEP RATE=calc(var(--scale-factor)*12.06px) =calc(var(--scale-factor)*12.06px)----=calc(var(--scale-factor)*12.06px) =calc(var(--scale-factor)*12.06px)10=calc(var(--scale-factor)*12.06px) =calc(var(--scale-factor)*12.06px)MHz
As far as I know I did not exceed these limits. 5v to the High output and 0v to the low output
Damn that what you see is what you not get editor....
Last edit: 15 May 2023 18:35 by MartijnD.
15 May 2023 18:38 - 15 May 2023 18:39 #271419 by PCW
Your schematics show 7I96S step and dir outputs connected to 5V or ground
This can damage the 7I96S.
For single ended drive, you leave the unused pins unconnected
Last edit: 15 May 2023 18:39 by PCW.
  • Moderator
  • Moderator
15 May 2023 19:48 #271421 by tommylight
Replied by tommylight on topic Connect a MKS Servo57c to a Mesa 7i96s
Will you do the honors, please?
Thank you.
Moderators: PCW, jmelson
Time to create page: 0.358 seconds
