Mesa 7i96s with 7i85s daughter card
- maxguapo
22 May 2023 09:19 - 24 May 2023 18:47 #271913
by maxguapo
Mesa 7i96s with 7i85s daughter card was created by maxguapo
Hi, I recently purchased the two Mesa cards above. The 7i96S is recognised by LinuxCNC (after using a crossover cable
) without any problem, but the daughter card does not show. When I run halrun only the pins of the 7i96S are shown, but not the 7i85S. Do I have to flash another firmware or what? On the homepage of Mesa their is no Firmware for the 7I96s to download. Where from to get?
Many thank's for any help!
Kind regards, maxguapo
Sorry for disturbing, but I do not get around with the two boards. I flashed the firmware 7i96s-7i85sd.bin to the 7i96s board. Unfortunately the 7i85s is not visible or could be accessed. Both boards have power and the flat ribbon cable is ok and only 15cm long.
Please help!
Please help!
Last edit: 24 May 2023 18:47 by maxguapo.
- maxguapo
22 May 2023 09:37 #271917
by maxguapo
Replied by maxguapo on topic Mesa 7i96s with 7i85s daughter card
Addition: The 7I85S has power, the led on the board lights up. Though this can not be the issue.
- Online
- Thank you received: 7491
22 May 2023 10:06 #271919
Replied by tommylight on topic Mesa 7i96s with 7i85s daughter card
Moved to "driver boards"
Time to create page: 0.082 seconds
