Configuration of 7i92TM + 7i76 error
07 Jun 2023 15:47 - 07 Jun 2023 15:48 #273081 by sharp_reaper
Configuration of 7i92TM + 7i76 error was created by sharp_reaper
Hello,
I'm using Linux debian bookworm 12 iso to use Probe Basic GUI (no problems in installation).
I have connected a mesa board 7i92TM with a daughter card 7i76.
Made IP configuration to 10.10.10.10 and the network can ping.
Made a PNCConfig using 7i92-Internal Data and then using the firmware 7i76x2 with one 7i76.
Had just one output to see if it's working but it shows an error: " Pin 'hm2_7i92.0.7i76.0.0.output-00' does not exist "
I've just flashed the firmware but it can't find the 7i92 board, it only find 7i92T board.
I've flashed the 7i92t board with "7i92t_7i76x2d.bin" file, and can read in --readhmid the pins but,
The error still remains.
I need help to configure my daughter board.
I've just tried to connect a 7i96s with the 7i76 and still can't connect my daughter card.
I've worked before with 7i92 with 7i76 and 7i76e with 7i76 and basically did the same thing and got it working.
What am I missing here?
Send my files in attachments, any other file needed please ask.
Thanks in advance for your help,
André
Last edit: 07 Jun 2023 15:48 by sharp_reaper.
07 Jun 2023 15:57 #273082 by PCW
Replied by PCW on topic Configuration of 7i92TM + 7i76 error
Do you have 5V and field power on the 7I76?
(both yellow LEDS on)
What does
mesaflash --device 7I92t --addr 10.10.10.10 --readhmid
print?
The following user(s) said Thank You: sharp_reaper
07 Jun 2023 16:24 - 07 Jun 2023 16:27 #273085 by sharp_reaper
Replied by sharp_reaper on topic Configuration of 7i92TM + 7i76 error
Yes I have the 5V and 24V in field. Tried both (from FPGA and external 5V, with the right Jumper set).
Edit: photo
mesaflash print.
File Name: mesaflash.txt
File Size:5 KB
Last edit: 07 Jun 2023 16:27 by sharp_reaper.
07 Jun 2023 16:30 - 07 Jun 2023 16:32 #273087 by PCW
OK that's the correct firmware
7I76 connected to P2?
7I76 W3 left?
No Watchdog bite?
Last edit: 07 Jun 2023 16:32 by PCW.
07 Jun 2023 16:54 #273091 by sharp_reaper
Yes, it is connected to P2 as shown in the photo above.
7i76 W3 is in left position (5V from FPGA)
The watchdog bite, but I've managed to put a higher number to debug the daughter card
07 Jun 2023 17:02 #273092 by PCW
If you are getting watchdog bites it may be that setup
packets are being dropped.
You may need to debug the real-time issues first.
07 Jun 2023 17:06 #273093 by sharp_reaper
What should I begin with?
07 Jun 2023 17:15 #273095 by PCW
I would comment out the field I/O pins in the hal file (or make a config without any)
and run it for a while and the check the dropped packet count:
hm2_7i92.0.packet-error-total
07 Jun 2023 18:48 #273100 by sharp_reaper
I'm away from the PC now, when I get there, update this thread.
I do had some trouble with the servo period and runned latency test.
Thank you for your help.
09 Jun 2023 08:26 #273232 by sharp_reaper
After running for a while the value stayed at zero.
Moderators: PCW, jmelson
Time to create page: 0.152 seconds
