Configuration of 7i92TM + 7i76 error
- Thank you received: 5334
09 Jun 2023 13:37 #273239
Replied by PCW on topic Configuration of 7i92TM + 7i76 error
That looks OK
Do the step/dir outputs work?
(check the dir pins when jogging back and forth)
The following user(s) said Thank You: sharp_reaper
- sharp_reaper
- Thank you received: 7
09 Jun 2023 16:17 #273243
by sharp_reaper
Replied by sharp_reaper on topic Configuration of 7i92TM + 7i76 error
Yes, it is working now.
Step/dir working on counts pin and physcally on hardware it's ok.
But I had to change a brand new board (7i76) for other brand new board (7i76) and it acknowledge the card and I was able to connect to the daughter board.
09 Jun 2023 16:24 #273244
OK sounds like a failed 7I76 card if another works
This should be returned to Mesa for warranty repair/replacement
Time to create page: 0.155 seconds
