Configure 7i78 with 7i96s
11 Jun 2023 19:20 #273344 by stavy
Configure 7i78 with 7i96s was created by stavy
I configured successfully 7i96s but I don't find any information how to configure a daughter card. I tried to only MesaCT but there is a bug that disable the tab for configuration. In pnfconfig there is tab called P but I don't really find anything useful there for adding motor.
I guess it should be done through the HAL file but not idea where to start, where I can gather more information about it?
Thanks!
  • Moderator
  • Moderator
11 Jun 2023 20:00 #273347 by tommylight
Replied by tommylight on topic Configure 7i78 with 7i96s
From what i can gather, 7i78 is one part of 7i76, so i would venture a guess that you would have to choose that.
In that case, that might require flashing the firmware on the 7i96S, but to be sure use MesaFlash to find out what firmware is already installed:
mesaflash --addr 10.10.10.10 --device=ETHER --readhmid
The following user(s) said Thank You: stavy
11 Jun 2023 20:16 #273348 by stavy
Replied by stavy on topic Configure 7i78 with 7i96s
I already flash the correct firmware using MesaCT (7i96s_7i78d.bin).
Maybe I didn't express my problem well enough so let me try to this one more time. In my CNC system there is 6 motors so 5 goes to 7i96s with no problem and the last one needs to go with the 7i78... I don't know how to configure this or from where learn about this more
Thanks,
Stav
11 Jun 2023 21:54 #273355 by PCW
Replied by PCW on topic Configure 7i78 with 7i96s
I suspect you will have to hand edit the hal /ini files for this
(stepgen 5 will be on 7I78 stepgen 0 pins)
I would start with a configuration for just a 7I96S. Then the main work is copy
pasting bits of the original hal and ini files to add the missing joint and pid comp
Is this 3 axis and 6 joints or something more exotic?
11 Jun 2023 22:15 #273356 by stavy
The machine will be XY1Y2ZBC.
I guess you right about editing the hal & ini files...
I'm up to the task and ready to learn whatever is needed but It's really difficult to find resources about this specific task. There is anything like this somewhere?
Thanks!
11 Jun 2023 22:57 #273358 by PCW
I would create the partial configuration and then read the hal and ini files
in conjunction wit the hal documentation, As I said, the task is really just copy/paste/change numbers...
12 Jun 2023 12:38 #273388 by stavy
I'll try to do it.
Thanks! :)
Moderators: PCW, jmelson
Time to create page: 0.135 seconds
