- Hardware & Machines
- Driver Boards
- Mesa 7i96 setup issue [parameter or pin 'hm2_7i96.0.watchdog.timeout_ns' not fou
- camb0
- Thank you received: 9
13 Jun 2023 11:48 #273481
by camb0
Replied by camb0 on topic Mesa 7i96 setup issue [parameter or pin 'hm2_7i96.0.watchdog.timeout_ns' not fou
Hi Rod,
Thx for the tips re running from the command line, I'll give that a try later tonight.
As per my other post there were some transposing errors that you saw, so I think the spaces and underscores are ok. I agree though I'll keep it simple and then expand it from there.
Re the 5V I've got a proper power supply to the board but I'll check your video shortly and verify I've done it correctly.
- camb0
13 Jun 2023 22:41 - 13 Jun 2023 22:41 #273521
by camb0
Thanks all problem solved, I really appreciate the assistance.
I knew it would be obvious looking back so many 'slaps forehead' moments past and coming up.
For others it was the card name, its a 7i96S not 7i96.
Having said that I would have assumed that the return result of readhmid would include the 'S', I see that -verbose option does.
$ sudo mesaflash --device ETHER --addr 10.10.10.10 --readhmid
Configuration Name: HOSTMOT2
BoardName : MESA7I96
Last edit: 13 Jun 2023 22:41 by camb0. Reason: formatting
- Driver Boards
