7i76 wiring query
17 Jun 2023 04:43 #273732 by rajsekhar
7i76 wiring query was created by rajsekhar
Hello everyone..
I am wiring a 7i76.
Query: should I use shielded wire for input and output connections or normal single core wire is sufficient ?
I am using 24V DC field voltage.
  • Moderator
  • Moderator
17 Jun 2023 09:12 #273738 by tommylight
Replied by tommylight on topic 7i76 wiring query
What is it used for? Plasma? Mill? Lathe? Robot?
Most cases unshielded is OK.
Some cases shielding is a must, like Plasma, but again not for everything.
We need to know what you are wiring.
And shielding does require some knowledge to avoid ground loops.
17 Jun 2023 09:54 #273739 by rajsekhar
Replied by rajsekhar on topic 7i76 wiring query
Plasma..inputs from home and limit switches
  • Moderator
  • Moderator
17 Jun 2023 10:34 #273740 by tommylight
Everything shielded, shield connected only on the control box to one single ground point.
Moderators: PCW, jmelson
Time to create page: 0.199 seconds
