7i96 - are 5v and Gnd pins converted to GPIO
- beefy
- Thank you received: 58
19 Jun 2023 10:30 - 19 Jun 2023 10:30 #273833
by beefy
7i96 - are 5v and Gnd pins converted to GPIO was created by beefy
Regarding the stock config setup on a 7i96, you get 5 step/dir pin sets, and 1 serial pin set.
Each of these pin sets comes with 5v & Gnd pins too.
If any of these pins sets are disabled, thus causing the pins to become GPIO, does this also apply to the 5v and Gnd pins, or are they permanently connected to the boards 5v and Gnd buses.
Last edit: 19 Jun 2023 10:30 by beefy.
- Thank you received: 7491
19 Jun 2023 16:55 #273864
Replied by tommylight on topic 7i96 - are 5v and Gnd pins converted to GPIO
They are permanently 5V and gnd.
Is this a 7i96 or 7i96S ? They do have some differences, but pretty sure the above is valid for both.
- beefy
19 Jun 2023 20:00 #273870
by beefy
Replied by beefy on topic 7i96 - are 5v and Gnd pins converted to GPIO
Great, thanks.
Mine is the older 7i96, not the S version.
Time to create page: 0.206 seconds
