- Hardware & Machines
- Driver Boards
- Ref: Mesa ethernet setup for 7i92, 7i96, 7i76E and other ethernet Mesa boards.
- fletch
- Thank you received: 72
01 Jul 2023 10:19 #274578
by fletch
Ref: Mesa ethernet setup for 7i92, 7i96, 7i76E and other ethernet Mesa boards. was created by fletch
Ref topic: Mesa ethernet setup for 7i92, 7i96, 7i76E and other ethernet Mesa boards.
forum.linuxcnc.org/27-driver-boards/3559...ethernet-mesa-boards
The above topic is locked so I can't reply to it but this is an additional step if you are using WiFi or other additional nework connection:
When editing the Mesa ethernet connection as per the original topic instructions, click on 'Routes' and select 'Use this connection only for resources on its network'.
This will stop other network request (Firefox etc) from trying to route through the Mesa card.
The following user(s) said Thank You: tommylight, Clive S
- Thank you received: 7491
01 Jul 2023 13:18 #274601
Replied by tommylight on topic Ref: Mesa ethernet setup for 7i92, 7i96, 7i76E and other ethernet Mesa boards.
Thank you Fletch.
It was there, but it appears i removed it when i edited the original post.
I will add that later.
The following user(s) said Thank You: fletch
- Driver Boards
Time to create page: 0.259 seconds
